removing carbs
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 02:04 #482503 by STUNTMAN STEVE
Replied by STUNTMAN STEVE on topic removing carbs
Is there an easy way to get to the inner two drain screws without having to take the bowls off? Id rather not have to refill the carbs on the bench...
'84 gpz750 work in progress/ money pit
  • Motor Head
11 Oct 2011 09:34 #482526 by Motor Head
Replied by Motor Head on topic removing carbs
The fuel Bowls should be orientated to have the drain screws facing outwards. The two on the right face right, the two on the left face left. You need to have a constant fuel supply hooked up. So the bowl fills lifts the float and then the fuel will shut off. 12mm Below the gasket surface? That would be absolutely huge, is that possible? Make sure the flow of fuel to the carb while testing is keep up. The fuel should rise up the clear tube, but sometimes there is an Air bubble. Make sure of no Air bubble.
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 14:48 #482562 by STUNTMAN STEVE
Ok. I was doing it wrong. Starting over today
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 16:40 #482577 by STUNTMAN STEVE
ok. i elevated the tank, hooked the gas to the carb inlet, set up my clear tubes, and leveled the carbs. when i put the petcock to prime to fill the carbs, the 3 and 4 carb started pouring gas out of the airbox side opening... does that mean my floats are stuck open on that side? god i hate this bike some days...
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 16:46 #482578 by STUNTMAN STEVE
also am i supposed to have the petcock on prime, or on? thanks
11 Oct 2011 17:01 - 11 Oct 2011 17:05 #482579 by 2wheeladdict
Replied by 2wheeladdict on topic removing carbs
you need vaccum for the petcock to work when in the on position. prime will flow with gravity. I used a small funnel and put it in the end of the fuel line hooked to carbs and poured gas in till it was visible in the funnel. then check clear tube. when done just lower clear tube and drain gas back into gas can or suitable container. Sounds like sticking float needles. try tapping the bowls with the handle end of a screwdriver. sometimes that will loosen a stuck float needle. Good luck
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
Last edit: 11 Oct 2011 17:05 by 2wheeladdict.
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 17:07 #482580 by STUNTMAN STEVE
alright. gotta get a funnel. if it pours out of the carb body when using the funnel? when i had it on prime is when the gas poured out of the carb opening..
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 17:13 #482581 by STUNTMAN STEVE
this is what it looked like after i primed the carbs full
if im doing it correct at all, it looks like 3 and 4 are way high...
  • STUNTMAN STEVE
  • Topic Author
11 Oct 2011 17:14 #482582 by STUNTMAN STEVE
oops
11 Oct 2011 20:58 #482621 by P21
Replied by P21 on topic removing carbs
yep that last picture outside carb fuel level WAY too high
Kawasaki KZ 1000 Police (2002) P21
11 Oct 2011 22:43 #482646 by wayno
Replied by wayno on topic removing carbs
hi steve, just reset the hi floats to be the same as the others.Now that you have the tank off, drain it, flush it out, remove the tap & clean out the filter(s)in the tap.Then do a fuel flow check into a measured jug over 10 sec.Get a figure an right it down.then repeat it, and get a average.Then add a inline fuel filter & repeat the flow test.I have discovered that fuel filters drop flow by 33%.IE was 150mls no filter then 100MLS with a filter)it didnt matter if it was a paper pleated filter or a sintered filter big or small.THEY ALL knocked flow by a heap!Keep this in mind if you ever trying to rejetting a carb.It can be running out of fuel in the bowl which can confuse you into making wrong decisions.Wayne australia kz900
  • STUNTMAN STEVE
  • Topic Author
12 Oct 2011 00:23 #482687 by STUNTMAN STEVE
Im backing up a bit but when im checking the float level from the tank; do I leve the tank on prime? Or just fill the carbs?
