removing carbs
- STUNTMAN STEVE
10 Oct 2011 21:07 #482411
by STUNTMAN STEVE
'84 gpz750 work in progress/ money pit
removing carbs was created by STUNTMAN STEVE
Any secrets to getting the carbs out with stock airbox? The manual says pull them up and out to the right side...? Mine don't wanna budge lol.
84 gpz 750
84 gpz 750
- Motor Head
- Thank you received: 391
10 Oct 2011 21:19 #482413
by Motor Head
Replied by Motor Head on topic removing carbs
At the rear of the box, on both sides you should find a small "L" shaped bracket held by 1 bolt. Remove the bolt on each side, and let the box back as far as it can go. I push the carb rack back first, then twist upwards on the front to clear the Intake boots. Then it will slide out either side, once out a ways the cable will unhook.
New rubber Airbox connecting boots make the job MUCH easier.
- STUNTMAN STEVE
10 Oct 2011 21:46 #482421
by STUNTMAN STEVE
Replied by STUNTMAN STEVE on topic removing carbs
Haha, actually while I was looking for the bracket you described, I pushed one of the carb boots in to the arbox, and had alot more room to pull th carbs out of the manifolds. Dude your a lifesaver. It was still a hard wiggle, but got them out!
- STUNTMAN STEVE
10 Oct 2011 21:48 #482423
by STUNTMAN STEVE
As a side note.. should I be consolidating these posts into one of my other threads? Sorry if I keep making too many threads about this one bike
- Motor Head
10 Oct 2011 21:49 #482425
by Motor Head
That's another method, push all 4 boots into the airbox. More than 1 way to skin a cat.
- STUNTMAN STEVE
10 Oct 2011 22:00 #482430
by STUNTMAN STEVE
Truth. Do you know the length of the tuubes for the clear tube method of checking float bow heighth?
- STUNTMAN STEVE
10 Oct 2011 22:13 #482435
by STUNTMAN STEVE
Got them on the bench, going to try the clear tube method. Do you know the length of the clear tubes or does it matter?
- Motor Head
10 Oct 2011 22:16 - 11 Oct 2011 10:18 #482437
by Motor Head
You can pick up some clear tubing at Lowes. Only needs around 1 foot, just enough to go from the bottom bowl fitting up along side the carb. You can get 4" and measure all 4 at the same time, so you can compare Levels.
Also you can make a cheap Manometer to use for Syncing them. Ask and I'll explain.
Here it is all written up in "Filebase" by a kind Member:
www.kzrider.com/filebase/doc_download/18...fferential-manometer
There is a lot of Carb info in there.
www.kzrider.com/filebase/cat_view/231-not-model-specific
Last edit: 11 Oct 2011 10:18 by Motor Head.
- STUNTMAN STEVE
10 Oct 2011 22:24 #482442
by STUNTMAN STEVE
Cool. I've got about 10feet of the stuff, just didn't know how long each needed to be. I guess liquids liquid and will just rise to whatever level it is.?
- Motor Head
10 Oct 2011 22:26 #482443
by Motor Head
Thats right, just needs to be higher than the fuel level, and enough to attach so it stays in place. Zip tie to the side of the carb works for me.
- 2wheeladdict
10 Oct 2011 22:48 #482449
by 2wheeladdict
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
Replied by 2wheeladdict on topic removing carbs
I also pushed the boots into the airbox and made the job much easier. I bought new boots on from z1. I would have never got everything hooked back up and kept my sanity without them. I even tried the hot water method with no luck. I noticed that my old boots were about 25% smaller than the new ones because of shrinkage. just my .02
80 KZ1000 LTD
84 CR60r
- STUNTMAN STEVE
10 Oct 2011 23:04 #482454
by STUNTMAN STEVE
Gotcha. Just checked the outer two, wasn't able to get to the inner two drain screws. Ill take another shot at it in the morning. The outer two were a whopping 12mm from the carb bodies!
