motion pro sync tool,
  • stonemaster
  • Topic Author
  • Visitor
18 Aug 2010 19:38 #392016 by stonemaster
motion pro sync tool, was created by stonemaster
the FSM give readings for vacuum gauges, but i have the motion Pro sync tool (which has no numbers just marks), anybody know the preferred reading or level for VM 28's on Z1 900 for this tool???
18 Aug 2010 20:07 #392028 by DFIGPZ
Replied by DFIGPZ on topic motion pro sync tool,
I just use the gauges to make sure readings are the same. it also helps to make sure valves are adjusted properly and no vacuum leaks on the motor.also check and verify ignition timing to make sure its correct,at that point you have done everything to make sure of a good accurate carb sync with the engine present condition. any other problems require major engine maint such as valve job, piston rings etc.
1984 750 Turbo
  • stonemaster
  • Topic Author
  • Visitor
18 Aug 2010 20:40 #392038 by stonemaster
Replied by stonemaster on topic motion pro sync tool,
ok thanx
  • mark1122
  • Keep twisting it
19 Aug 2010 04:43 #392068 by mark1122
Replied by mark1122 on topic motion pro sync tool,
X2:)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
19 Aug 2010 08:56 #392128 by timebomb33
Replied by timebomb33 on topic motion pro sync tool,
figure out which carb has the highest reading and then set the other carbs to it the most important bit of info is get them even. also when you make an adjustment blip the throttle abit to settle things down
I THINK MY POWERBAND BROKE
  • mark1122
  • Keep twisting it
19 Aug 2010 09:44 #392135 by mark1122
wouldnt you adjust them all to the master carb.
dont VM 28's have a master?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
19 Aug 2010 09:48 - 19 Aug 2010 09:49 #392138 by TexasKZ
Replied by TexasKZ on topic motion pro sync tool,
Timebomb33 raises an interesting question - would an engine with carbs synch'ed to the lowest vacuum reading run the same as one synch'ed to the highest?
(Ooops, I should have said the same engine synch'ed each way, doh!)
Last edit: 19 Aug 2010 09:49 by TexasKZ.
  • mark1122
  • Keep twisting it
19 Aug 2010 09:52 #392141 by mark1122
You dont have that option, if u have a master carb.
it makes no dif.
all u are doing is adjusting the slide height to get the same amount of vacuum, then u will adjust all carb slides together, up or down, with the linkage idle screw to achieve the proper rpm.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
19 Aug 2010 14:41 #392190 by Jeff.Saunders
Replied by Jeff.Saunders on topic motion pro sync tool,
I do use carb sync tools, but I'm very careful about how much I adjust the carbs AFTER I've synced the carbs on the workbench.
If you are dealing with an old set of carbs, the sync at idle can be influenced by wear in the carb. Air can leak past slides and idle passageways may not flow fuel or air the same as when new due to corrosion or gasoline deposits.
With Z1 and fully mechanical carbs (not a CV carb). I sync the slide heights with a thin round piece of metal (actually a partially unwound paperclip). Then when I make an vacuum adjustments I only tweak any one adjuster a very small amount (1/4 turn or less).
I adjust the air screws/fuel screws to help sync the idle more than any slide linkage adjustment
While a super smooth idle is nice, it's more important to have the slides fully sync'd when the needle / needle jet come into play in the mid range.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
19 Aug 2010 16:49 #392240 by timebomb33
most older slide carbs don't have a locked in place carb you can raise and lower the slide heights individually cv carbs on the other hand do use a locked carb usally number 3. so you have to tune the other carbs to that one
19 Aug 2010 17:01 #392243 by 650ed
Replied by 650ed on topic motion pro sync tool,
What's a "master carb?" Ed
19 Aug 2010 18:29 #392267 by timebomb33
the carb that the other 3 are sync'd to.
