11012-1128 plug over pilot jet no longer available
- DoctorRoboto
Re: 11012-1128 plug over pilot jet no longer available
19 Jul 2015 18:46 - 19 Jul 2015 18:47
Okay folks, an update for you. Today I was able to successfully take the measurements off of what was left of my broken plastic plugs, the critical features of the carb body itself, and the geometry from the photos of the plastic part, and then turn down some replacement plugs out of aluminum on a jeweler's lathe. The result - a fantastic replacement that seems like a perfect fit, and is much more durable than the OEM parts. Attached is a photo of the pair.
The plugs are much easier to get in there now, and I think they're going to hold up great. They take advantage of the tang on the float bowl, so I know they're not going to fall out. If anybody is interested in a pair / set of these, let me know.
Attachment DSC_0456.jpg not found
'83 Kawasaki KZ440-D5
'71 Honda CB175 K5
'75 Suzuki DT175
'78 Honda CB400TII
'07 V-Strom 650
'71 Honda CB175 K5
'75 Suzuki DT175
'78 Honda CB400TII
'07 V-Strom 650
Last edit: 19 Jul 2015 18:47 by DoctorRoboto. Reason: Typo
- JR
19 Jul 2015 19:17
Very classy
really nice job
really nice job
- Randombeat
- 0 to 100 real quick...
19 Jul 2015 20:56
I'd be interested in a set of four, depending on cost of course.... Pm me?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- EricTheLeg
16 Aug 2015 17:47
DoctorRoboto scores!
I ordered two of the plugs from DrRoboto and put them in today. They appear to perfectly match the dimensions of the plastic ones included the o-rings and went in easily, yet seated firmly. Although I haven't yet ridden any sort of distance with them, for the short ride I took around the block the bike was running well!
1983 Kawasaki KZ440 LTD D/Belt - the road bike
1986 Husqvarna WR400 - the dirt bike
1985 Husqvarna WRX400 - The Project bike
- daveo
16 Aug 2015 19:54
No eBay APP ID and/or Cert ID defined in Kunena configurationOriginal design as per ebay listing. :huh: See:
A similar adaptation (of 920661087) for the BS34 may be in order...easier to extract, and reuse vs. replace. :kiss: See:
www.cmsnl.com/search/partnumber.php?spbp...61087&spbpmodelcode=
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
- BLibecap
18 Oct 2021 10:32
No eBay APP ID and/or Cert ID defined in Kunena configurationyou might try searching ebay for the part CAP,POLYESTER 11012-1128
The following user(s) said Thank You: JR
- JR
18 Oct 2021 16:46
18 Oct 2021 17:01
$10 each. They look nice but pricy. I'll make brass ones for that price.
- Mad Anthony
22 Jan 2024 12:01
Nessim, a couple of years ago you offered to fabricate some of the plugs/caps. Still in the business? what would you charge to make a couple of these from brass today?
22 Jan 2024 15:51If you just need two, I may be able to find you a couple of decent used plugs.Nessim, a couple of years ago you offered to fabricate some of the plugs/caps. Still in the business? what would you charge to make a couple of these from brass today?
- Mad Anthony
25 Jan 2024 22:47
Yes I only need two. Are you talking about the OEM polyester plugs? ... or brass? Mine OEM plugs are so brittle I was thinking brass might be better. How did those work out?
- SnyperX
31 Oct 2024 22:01I know those post is old, but i came across it after I freaked after losing one of my plugs. Nessism, are you still able to acquire/make/obtain these plugs? I am desperate to locate some. Please let me know. Thanks.If you just need two, I may be able to find you a couple of decent used plugs.Nessim, a couple of years ago you offered to fabricate some of the plugs/caps. Still in the business? what would you charge to make a couple of these from brass today?
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
