11012-1128 plug over pilot jet no longer available
- radon220
01 Jul 2010 08:09
So I think we all know this plug is no longer available... I'm looking for other people's workarounds.
The workaround I'm currently attempting is a dab of RTV over the pilot plug hole. I like it because it's easy to peel off... but I know it's not the ideal material for fuel soaked application. I'll be taking the float bowl apart again after putting about 3 weeks and 90 miles on it with this fix. I guess we'll see how it worked.
I suppose one could widdle a plug from a hunk o plastic... O-rings are easy to come by.
What's your workaround?
Don in CT
81 KZ440-D2 belt drive
- otakar
Re: 11012-1128 plug over pilot jet no longer available
01 Jul 2010 08:14
Most rebuild kits come with these plugs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
01 Jul 2010 08:20
I just looked on Kawasaki.com and the part is still available. According to Kawasaki.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- radon220
01 Jul 2010 08:26
I haven't tried purchasing from Kawasaki.com, but I will now. However my dealer can't get it, ronayers can't get it, bikebandit can't get it... and all the forum threads I've seen say it's no longer available. (ie
kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=263258
Don in CT
- otakar
01 Jul 2010 09:14
If you go to the Kawasaki.com websight and look up your bike it states that it is available in limited quantity. Otherwise look up arebuild kit for your carbs and I think you will see it in there. Otherwise you can also use a test tube stopper in the hole just cut it to length.
www.mcmaster.com/#tapered-plugs/=7rtw44
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Polar_Bus
08 Jul 2010 09:27
If the Kawi plugs are discontinued, the plugs for the GS 1000/1100 Suzukis' will work as well.
Suzuki p/n 13357-44080
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- OnkelB
08 Jul 2010 09:43
Polar_Bus wrote:
Those are the ones I have in my BS34s - they are not a perfect fit as they are slightly too large at the bottom of their taper, but once the float bowls are installed that's not a problem.
Got mine from Z1E, just below $10 for a set of four:
www.z1enterprises.com/detail.aspx?ID=1962
77 KZ 650 B1, 82 GPz 1100 B2.
- otakar
08 Jul 2010 09:49
That's $40 @4 at Z1E and $7.16 @50 at McMaster.
www.mcmaster.com/#6448K89
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- radon220
08 Jul 2010 10:14
I'll try the McMaster stoppers next... hopefully they can withstand soaking in fuel. Rather than waiting for them to ship, I went to Sears Hardware and found a test tube stopper that fit. It swelled to 3x its size while soaked in fuel and blocked the travel of my float. One rich condition traded for another
Z1 is currently out of stock for the suzuki version.
If the McMaster stoppers dont work, I might just tap the hole and and use a threaded plug or machine screw with some sealant on the threads.
Don in CT
- OnkelB
08 Jul 2010 10:26
otakar wrote:
Nope, $9.57 is for one 4-pack - hard to beat $7.16 for 50 though..
- otakar
08 Jul 2010 11:04 - 08 Jul 2010 11:10
The stoppers are made out of EPDM. This is not Great for Gasoline but is OK your other choice is to get an "O" ring that has a 1/4 " cross section and cut it up for these plugs. I have done that also. If you get Viton or Nitrile (Buna-N) it will be as good as OE. Viton would be the best. If you don't want to trust the stoppers than make them out of this. 9029K12
www.mcmaster.com/#viton-fluoroelastomer-rubber-rods/=7vgzap
These will last forever.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Jul 2010 11:10 by otakar.
08 Jul 2010 15:55 - 08 Jul 2010 15:57
Perhaps not feasible for this application, but sometimes a hole may be plugged with a small round fish line lead weight, by just mashing it down inside the hole.
Last edit: 08 Jul 2010 15:57 by Patton.
