- Thank you received: 109
OMR: Emission Tester AVI Clip.....
- mark1122
- Keep twisting it
i have always tuned the low end up by adjusting to the highest idle rpm, by ear.i do find it very difficult with the rs carbs though. the rs carbs dont have as fine a tuning window as most. the pilot air screws are to be turned a max of 1/2 turn out from seat, rather than the usual 2 turns.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- loudhvx
- Thank you received: 1616
www.innovatemotorsports.com/
You can get a setup like mine new on ebay for about $200, but probably cheaper if you fight it out on the bidding.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
As Loud mentioned, this would truly only be useful during a load test... Meaning while the bike was running down the road at mid range 4K-6Krpm for the desired 13.8 reading....
If you guys remember, I had originaly designed this as a mid exhaust sensor AFR meter... Did it work yup to what degree hard to say for I have nothing to verify the accuracy with...
As for the emission test... It provides the required results for non load emission passing standards to use as a reference... Truly nothing more but interesting just the same....
I saw that unit Loud but hey, as with you, was thinking ah hell, I can make my own... :S :laugh: :laugh: :laugh:
I guess I was bored....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- loudhvx
why would u stay away from the LM-1, LM-2 ?
Based on their discussion board, it seemed like some people were having trouble with them operating correctly. the LM-1 might be ok, but's no longer available, from what I remember. Plus they are bigger and would be more difficult to find a mounting spot for them.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
[quote
[/quote]
I considered that too. But it ended up being cheaper to buy it. It's a really nice unit and the software was very simple to program it (though it's already setup for gasoline, wideband and calibrated for the gauge, if you don't want to mess with connecting a PC). There are options on where the needle will sit during warm up etc. I was expecting headaches with it, but it works surprisingly well.
1981 KZ550 D1 gpz.
Other links.
- mark1122
- Keep twisting it
i am kind of liking this one.
www.innovatemotorsports.com/xcart/produc...16235&cat=273&page=1
do u think there are any pros or cons towards the digital or anolog?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
"02 would be more useful for cruise and mid range throttle adjustments. is that an accurate statement"...
thats what i was thinking. u could set up the idle with the gunson to tune each carb. then tune the cruise and mid with the o2 while driving.
do your plugs , give u the color u want , tan?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
During me research and quest for learning carb jetting, I discussed this with Larry & plum and here's the deal... Makes perfect sense....
Due to corn ethanol and other additives here for air pollutants in AZ as well as what I've done in my engine build, TAN is just not going to happen...
Then throw into the theory of the "How to Read Spark Plugs Correctly" tan is not necessarily what your looking for... See when that article was most likely first written we had leaded gasoline and who knows what in the fuel...
Now I'm sure some of you may be obtaining a TAN color in your fuel supplies in your area, who knows and frankly doesn't matter for my situation...
Ground banding strap...
Insulator speckle for pre/post detonations...
And ESPECIALLY Base ring...
These three variables, AFR measurements, emission test results, head conditions & Port and Polish CFM flow, timing, performance cams and the almighty how she performs tell me everything I need to know....
Long story short :blink: , nope NO TAN!... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
Nope, no tan what so ever... I have never been able to achieve any indication or slight coloring of tan....
OMR
i agree with everything u said.
i could no longer predict the carb adjustments by plug color. i felt i could a couple of years ago with my last motor and vm carbs, but not now. i cant get repeating results with the metal base ring either. so last year i started to develop a tune by feel approach. i'm sure it may not be spot on , but it FEELS like it is.at least i cant feel any week spots. i would love to test the feel method with the aid of the 02 sensor, just to verify things. mostly it would give me the confidence to lean out the cruise jetting to improve mileage, without worry..
Just curious, what color are the plugs? mine are dark brown, after 4500 miles .
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- loudhvx
1981 KZ550 D1 gpz.
Other links.
