- Thank you received: 1616
Car fuel filter on KZ
- loudhvx
21 Aug 2009 14:34 #315554
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Car fuel filter on KZ
Thanks VVC! That looks good. So where did you place it? Is it tucked between the #2 and #3 carbs? Or did you run it on the outside of the carbs and make the fuel line into a J shape?
1981 KZ550 D1 gpz.
Other links.
- violentvintagecycles
21 Aug 2009 14:56 #315559
by violentvintagecycles
Replied by violentvintagecycles on topic Car fuel filter on KZ
its between 2 and 3, i also had a big ass loop in mine when i had the original see thru filter, had problems with gas flow when i did, so this time i ran it so gravity was doing its job as well as the vacuum
- Russ Jackson
24 Aug 2009 11:30 #316130
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Car fuel filter on KZ
