- Thank you received: 337
Car fuel filter on KZ
- bountyhunter
I bought a couple of the glass filters with removable filters a few years back and never had the nerve to install them because of concerns of glass cracking. I should give them away.PLUMMEN wrote:
dont use the glass inline filters,i watched my neighbors 37 chevy burn to ground a few years back. fire dept told me it was common problem for the glass filters with metal end caps to leak.
Thanks for the heads up. I also wonder how strong the glass is.
- bountyhunter
I wish I could get a 5/16" sintered bronze filter in a clear container, but they are pretty scarce. I've seen some in aluminum containers, but they are a little too big to go where I want it.
These might fit.
cgi.ebay.com/ebaymotors/CHROME-FUEL-GAS-...mQQitemZ390072683108
Here's a clear one:
www.parkeryamaha.com/visufilterhigh-flow...lter516linesize.aspx
- Ironhorse
- www.ridelikeaprowestcoast.com
Might be another option.
Clear Filter
Good Luck!
I'm using those on three of my four KZ1000Ps. They seem to work fine. The fourth bike has a larger round shaped filter that was installed by a shop.
Real learning begins after you know everything.
- loudhvx
- Thank you received: 1616
These might fit.
Here's a clear one:
Thanks, those both look good. I've been looking at those aluminum cans with removable sintered elements. I thought they might be too big, but it's worth a try at this point. I hadn't seen that clear one before.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Thank you received: 2098
Sometimes the leakage results from a tight bend in the fuel line which stresses the fit onto the filter barb in situations where a straighter connection might prove leak-free.
A 90 degree filter might be the answer.
Filters
Redline also has the 5/16" aluminum sintered bronze version with replaceable element (but doesn't list the element or it's price as a separate item).
Good Luck!
- Russ Jackson
They cost $11.99 at JEGS
www.jegs.com/i/Russell/799/645120/10002/-1
Replacement filter element
www.jegs.com/i/Russell/799/651660/10002/-1
...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- JMKZHI
- Thank you received: 48
Z1Enterprises sells them - cheaper too. There are two sizes - I prefer the larger one.Might be another option.
Clear Filter
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- RonKZ650
- Thank you received: 240
- loudhvx
GPZ550 should all be 1/4" line. You could change to 1/4" and get the inline filter through Z1 or Bikebandit. The car filters must be made for a pressurized system and don't like gravity feed.
Well, you would think 1/4" would be enough, but the fuel line connection pipes measure 5/16", and the barbs are actually closer to 3/8". It would be quite a wrestle to get 1/4" line to fit.
Looks like I have at least a few options now. Even if I had to use reducers, it wouldn't be the end of the world, but it just looks like hell.
1981 KZ550 D1 gpz.
Other links.
- loudhvx
If this filter's claims are true, I'd probably try this first. I'm wary, though, because it looks like more of the same as what I've been using.
1981 KZ550 D1 gpz.
Other links.
Why not search for a 3/8" filter instead of a 5/16" filter?
