bs 34's and pods..
- brianrae33
12 May 2009 18:48 #290665
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic bs 34's and pods..
had a 78 with the 1075 as well..stock cams and rebuilt vm28's froma z1r..thing screamed...pulled a 7.8 @ 92 in the 8th with stock suspension and street tires..
1982 kz1000ltd
- otakar
13 May 2009 04:31 #290746
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic bs 34's and pods..
Do either of you guys have the carbs that have the double butterfly valve? One on each side of the slide?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- brianrae33
13 May 2009 07:36 #290773
by brianrae33
- keith1
- Thank you received: 2
13 May 2009 16:48 #290892
by keith1
Replied by keith1 on topic bs 34's and pods..
brianrae33 wrote:
me neither....
not mine..
me neither....
- 88alltrac
14 May 2009 04:56 #291043
by 88alltrac
81 KZ1000 K1
Lincoln NE
Replied by 88alltrac on topic bs 34's and pods..
i had pods on my bs34's as well and it would hit redline no problem. i think i had 140 mains in it. maybe 137.5 i dont remember right now. only 1 butterfly valve.
paper filters on them.
81 KZ1000 K1
Lincoln NE
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
14 May 2009 16:52 #291228
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Replied by Bdog on topic bs 34's and pods..
Didn't know that the BS34s had butterfly valves on them. For choke? The ones that I have from a GPz750 do not have butterflies, just slides.
Otto, interested in the mods that you have been doing with the Mikunis and would like more info, is there a link or can you PM me the extent of envolvement. I saw the needles in the classifieds. Do those work for the small motors? Thanks.
Brandon
Brandon
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- otakar
15 May 2009 04:17 #291335
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
All CVs have butterfly valves. They are what actually controls the throttle. The slides are there only to lift the needles. This is why the slides are about 25% from the bottom to start with. The slides can however restrict the throttle, if they do not lift all the way. This can happen if the vacuum is insufficient to do so. Such as, by installing pd filters. This will greatly reduce your top end. The needles should work well on any MIKUNI 34CV carb system, which utilizes 3mm needles. They will not work on Keihin carbs. They must than be matched with the correct main jets for the application. The needles only affect the fuel flow from about 25% to 85% of the throttle setting.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
