bs 34's and pods..
- brianrae33
1982 kz1000ltd
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- brianrae33
1982 kz1000ltd
- keith1
- Thank you received: 2
- brianrae33
1982 kz1000ltd
- bigkzfan
- if grandpa had tits he"d be grandma, if
- Thank you received: 1
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
- otakar
jetted as per jeff saunders instruction..140 main..40 pilots..runs like a striped ass ape!!...minus the second gear issue which is soon to be fixed..very snappy throttle response..and loads of top end..didnt but new..had 26,000 on the clock..stock bars and 4-2 pipes..
This bike may have had a stage 3 kit put into it. Did it have a K&N filter in the stock air box? Did it have the lid on the air box?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kano
- Not Another Bloody Limey!
do you recommend dynojet stage 1 or 3
for my set up?
carbs
Mikuni bs34mm carbs by WG Carbs,
1 and a half turns out.
Main Jet #142.5Pilot Jet #40,
34mm K and n air filters,(pods)
motor
Gpz1100b1 motor 1170 cc, 3mm over size?,
4 - 1 Sidewinder headers viper oval can.
slightly ported,
standard cams from the b1
- kano
- brianrae33
1982 kz1000ltd
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
bike runs super....45 pilots and 135 mains 3 turns out.....strong on the bottom, good midrange and its still pulling well at 8500.....i got the chance to whack it open pretty good 3 times in a quick ride and it was still pulling at 8500.....the last one was an 8500 1-2 and i was like "this thing moves pretty good".....i couldnt be happier...this is the 3rd set of carbs i ve tried and i think i m home
on this set....its nice to finally cruise around low speed and have good response and have it relocate quickly when i whack it......:woohoo: :woohoo: :woohoo:
