- Thank you received: 1415
Pods on F.I.
- larrycavan
- Visitor
- larrycavan
- Visitor
- KZQ
- Administrator
Any way, I'd gladly loan it out to help an old KZ.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- otakar
I am an avid visitor to your web sight and have quoted you quite a few times here.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- larrycavan
- Visitor
I have one of the Kawasaki TPS adjusters, complete with flashing lites and all. Larry's suggestion is a good one but not perhaps suited for folks like me who loose the factory adjustment.
Bill
My way IS the factory support way. No kidding! HotLine told us way back to take that silly flashing light tool and chuck it!
You really don't need that thing at all.
We tested it out because we were curious. We set one with the tool and then set it the manual way. Bike ran better with our manual adjustment.
Think about it. That tool was made for stock motor and EPA. It doesn't know / care about different cams, airbox removed, header....etc.
- larrycavan
- Visitor
Hay Larry, what did that set you back. Do you have any opinion on my head work on mi Thread. kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
Otto
Otto,
96CFM is a nice street head. You did a nice job.
The bore on the throttle bodies was free. Good friend did them for me. Stock TBs flow about as well as a CV carb of same size. Pogue TBs flowed 143CFM @10".
Stock 83 TB w/o stack 114.7
Stock 83 TB with Stack 125.8
Sid Pogue bored throttle bodies with stack 143
Last September when I spoke with Sid, he would still do the throttle body bore.
- otakar
Otto
Otto,
Larry
This means that the stock throttle bodies should be more than adequate for my application since the head will flow about the same as the stock TBs? Or am I wrong to presume so. I do not have a welded crank and do not make a habit of dropping the clutch. I may accelerate briskly, but fluently. Did you ever get that linkage for the shift lever? I emailed you a couple of times to let you know that I had one, but you never answered.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
Anyone know if there are after market controllers available for these older systems?
Otto
Megasquirt is a good DIY programmable EFI computer that can do it.
Build Thread
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
