- Thank you received: 28
Gunson Color Tune AVI Clip....
- TeK9iNe
- What did you do!?!
according to mikuni (i think thats where I got this...)
..Or is this whats happening here, when you tune this way, at idle...
I confuzzled! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
You want this at idle and throughout all your ranges...
Excerpt out of the color tune literature...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Tony
- Thank you received: 13
I order it on the 17 of April and it showed up today, Apr.27.
56 dollars including delivery.
- Old Man Rock
Did you get a MORGAN Carb Sync (vacuum) as well, if so, You're really going to love that MORGAN unit.....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TeK9iNe
The problem I see with your diagram is you have to be at cruising speed for the correct 14.7:1 mixture to be obtained ....
WOW! Theres alot of diferent opinions out there on the internet... my mechanic had all sorts too.
So I'm told now, my diagram above is wrong for idle and WOT, by more than a few people.
So with this setup, your achieving stoich throughout the entire throttle range.
More and more, I'm hearing that a AFR of 12-13 is what will achieve the most HP at WOT.
...but, I don't know.:blink: Is that what the colortune thingy is helping you do? Or just stoich? Maybe I should be asking MORGAN! :woohoo:
...my 2 cents... this would keep things VERY clean inside that pretty engine... how often do I WOT? not much.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Tony
- Old Man Rock
Exactly! At idle, you're calibrating your carbs for the correct mixture at idle which works throughout your entire range.
As you hit the throttle you'll see the ignition flame go predominantly yellowish which is expected for your adding fuel :ohmy: :woohoo:
Of course, (entire range) also depends on ideal/correct jetting...
NOTE: Via keihin literautre in my case, find the ideal jet configurations for hp then go up one size in main jet! Translation, you want to be more rich then lean!!!
Or just stoich? :huh: :dry: :blink: :laugh:
Not sure what this is.....
Is this polish humor or something? :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Tony
- TeK9iNe
OK, I think I get how this thing works now. I'd like to tinker with one myself.
I think I just might wait and get a Wideband O2 sensor setup later... maybe.
:huh: :dry:
Redneck Rejet: Duktape or some o da arr felter to "richner' up" :laugh: :woohoo:
Cheers an thanks.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
Take note of the second test procedure.... Ahhhhhhhh!
Now this made a difference where previously, a slow twist would still leave me a little yellow where it should stay bunson blueish.....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bill_wilcox100
- Thank you received: 5
I tried to read this on my screen and then tried printing it on my laser printer and reading it... but it was not clear enough for my vintage eyes.
Any chance of getting a really high resolution colour scan and putting it in a convenient place here on the site?
Looks a lot better than the instructions I recently got with my new Gunson Colortune. Too bad they cut back on their documentation quality like that.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- Old Man Rock
Ask and thee shall receive...
members.cox.net/ruinsofstei/Color1.jpg
members.cox.net/ruinsofstei/Color2.jpg
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
