- Thank you received: 225
Gunson Color Tune AVI Clip....
- Old Man Rock
Could have been faster but I wasn't in a rush and wanted to see for myself the color changes as I adjusted my pilots....
One thing I noticed after the pilot adjustments is that I gained about 2" of vacuum pull that can be seen in the video... Sweet!
Here's a small clip where you can see the color change from Yellow (rich) to Bunson Burner Blue(ideal adjustment)...
In this clip, you can see where the vacuum has increased and in the volume you can hear how much better/smoother the motor idles.
NOTE: Still have to finalize the carb synch, still slightly off as can be reviewed by the gauges.
I'll continue this with a final clip once the Morgan arrives and is completed....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Mark Wing
Mark
Yorba Linda Cal.
- kano
- Not Another Bloody Limey!
12mm or 14mm omr?
sounds good happy yet lol?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- eddiem
- KZR FLAG RELAY CARRIER #63
- Thank you received: 34
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- Old Man Rock
Once I Morgan synch, I want to go through the pilot adjustment one more time. In reading the literature, you want to adjust just where the flame goes from yellow to blue. It's stated at this point your still a little on the rich side compared to being lean. Then I'll keep an eye on the plug color to obtain that nice tanned brown color....
Obviously this has me a little spooked due to a brand new motor where I'd rather be on the rich side for now....
Anyhoot, nice tool, made one hell of a difference to a carb noob as myself.... hlol
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
didn't go to big with them which is a common mistake some people think if some is good,lot's is better not always
Most definitely....I'm totally with you there brother
While doing my carb research on what I had in mind for performance, throttle response, driving patterns and in considering my age & riding style, I didn't need to go any larger.
In speaking with Larry C and Buzz over at Dynoman.... After stating the above mentioned variables, especially age and riding style they both stated the exact same thing.... Whoa talk about being spooky... Almost exact word for word replies... And now you say the same where these 29mm where the ideal choice....
As mentioned many times now, don't care if I'm off the line first for not drag racing this bike nor do I care if I gain an extra 10mph on the high range for at my age, I just don't see myself going over 120mph.
Too much to loose to be so reckless at this phase of life...
With my choice of piston kit (1015cc), camshaft (.365) and carb selection (29mm), I will have an extremely strong running motor with exceptional low to mid range response and performance, just where I want it....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- arai59
- Banned
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Always wanted to see one of those in action...
Wonder if it can be used to tune at high/higher throttle positions?..?
Cheers
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- HerrDeacon
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- HerrDeacon
