- Thank you received: 109
Gunson Color Tune AVI Clip....
- mark1122
- Keep twisting it
21 Feb 2009 15:01 #266857
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Gunson Color Tune AVI Clip....
Chalk up another 1 for Dave.
Super Dave , that is.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bill_wilcox100
- Thank you received: 5
21 Feb 2009 16:02 #266869
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Gunson Color Tune AVI Clip....
Cool tool!
Just asked Z1 Ent. to quote one.
Thanks for the video OMR.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
- 79MKII
- Love Them Kaws!
- Thank you received: 43
21 Feb 2009 20:37 #266960
by 79MKII
The Kaw List:
Replied by 79MKII on topic Gunson Color Tune AVI Clip....
It's about time you got that video posted!:laugh:
Just kidding of course - thanks for the info. I think I'll be ordering one of those too. I don't care what all the other guys say, you're all right! :laugh:
The Kaw List:
- 79MKII
- Love Them Kaws!
21 Feb 2009 21:14 #266972
by 79MKII
The Kaw List:
I went to youtube and looked for other videos of the colortune and yours is the best by far. All of the other ones are just yahoos reving their engines to see the color - and they're all yellow! Nobody bothered to show how it changing colors when you adjust the carbs, which is the whole point of the tool! Geez! Again, awesome job. I will order one tomorrow!
The Kaw List:
- Old Man Rock
- Thank you received: 225
25 Feb 2009 20:03 #268148
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Gunson Color Tune AVI Clip....
As can be reviewed in the attached avi clip, I received the Morgan Carb tuner and pretty much have the throttle valves adjusted where all 4 carbs are within 2cm of each other.
I realize there will be more fine tuning as I go through the jetting procedures for idle to 1/4 throttle and from 1/4 to 3/4 throttle and full throttle adjustments...
All in all, time to button her up, re-check my torques, install the tank and get her registered for her first < 50 mile road trip....
After which, drain and replace the oil and filter then make some more fine tuning adjustments.
Again, re-torque every nut and bolt on the bike, ALL of them....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Z1109R Fin
26 Feb 2009 03:01 #268169
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Gunson Color Tune AVI Clip....
So you like the Morgan? Easier and also more accurate than separate gauges?
BTW, thats how close synched I got my flatslides too. Makes a really really big diff.
- Old Man Rock
26 Feb 2009 03:49 - 26 Feb 2009 03:50 #268173
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Hey FIn,
Indeed, sweet set up... They use little re-stricter tubes in series in your hoses to the carbs where you don't have to dick around with valves...
As can be reviewed in the avi clip, very little bouncing around between each carb to another, very easy to dial them in in this manner.
As mentioned, I will still have some more tweaking to accomplish, today will go through the pilot adjustments and re-carb synch one more time. Basically double check/confirm I didn't miss anything....
Then set the idle ~ 800-1000 rpm...
From that, get her ready for her first road trip....
Keeping a keen eye on the spark plug insulator colors... Burning rich/lean and make adjustments as required...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Feb 2009 03:50 by Old Man Rock.
- Z1109R Fin
26 Feb 2009 04:20 #268176
by Z1109R Fin
Just Ride the he"l out of it and then check plugs etc;)
- Old Man Rock
26 Feb 2009 04:34 - 26 Feb 2009 04:35 #268178
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
OK, ok.... hahahahahahhaha
Yeah, Larry has been putting a size 10 in my arse as well.... Stating, enough already, ride the F'thing will ya.... hahahahahaha
What can I say, I'm anal that way... Or is it just I'm an a.... Oops, can't say the a-wipe word here.... KZR police (MODS) beat OMR with KZ fork.... OMR be good... :laugh:
Same time, bike hasn't been registered since 1985 so I need to get it through emissions here in Az... So I do need this fairly dialed in to pass....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Feb 2009 04:35 by Old Man Rock.
- mark1122
- Keep twisting it
26 Feb 2009 05:40 #268189
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Nice clip there Dave. I’m glad to hear it's all coming together .
Just out of curiosity.
When u noticed that the vacuum went up at idle during the color tuning, did u happen to check weather the vacuum was affected at part throttle? maybe that’s a given?? I don’t know.
I'm thinking that the rpm u want the most vacuum would be at the transition area to produce the best throttle response?
Maybe some other with more experience than me, could shed some light on this.
It is fact that with the use of larger carbs, u have less vacuum at low rpms, thus less throttle response.
I also wonder, if u could use these tools to verify exhaust baffle size changes, and there affects on low end vacuum signals??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
28 Feb 2009 10:02 #268662
by 79MKII
The Kaw List:
Do you guys see much use for the mirror set up that comes with the colortune? I found some units without the mirrors for like $30. Not sure if I'd need the mirror or not...
The Kaw List:
- Old Man Rock
28 Feb 2009 17:00 - 28 Feb 2009 17:01 #268748
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Not required as seen in the avi clip on the KZ900/1000...
This was included for those that have the deep valve covers and weird spark plug locations in the head....
If you can find one for $30, Hell of a deal, all you need is the 14mm see through plug and the 6" extension for the coil to spark plug boot connection...
Do share where you are buying for others....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Feb 2009 17:01 by Old Man Rock.
