Gunson Color Tune AVI Clip....
  • Old Man Rock
  • Topic Author
20 Feb 2009 18:20 #266611 by Old Man Rock
Gunson Color Tune AVI Clip.... was created by Old Man Rock
Well, I received the color tune kit today and I must say, extremely easy to use and complete all 4 pilot adjustments on my Keihin CR Specials in under 30 minutes...
Could have been faster but I wasn't in a rush and wanted to see for myself the color changes as I adjusted my pilots....
One thing I noticed after the pilot adjustments is that I gained about 2" of vacuum pull that can be seen in the video... Sweet!
Here's a small clip where you can see the color change from Yellow (rich) to Bunson Burner Blue(ideal adjustment)...
In this clip, you can see where the vacuum has increased and in the volume you can hear how much better/smoother the motor idles.
NOTE: Still have to finalize the carb synch, still slightly off as can be reviewed by the gauges.
I'll continue this with a final clip once the Morgan arrives and is completed....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
20 Feb 2009 18:27 #266614 by Mark Wing
Replied by Mark Wing on topic Gunson Color Tune AVI Clip....
She sure sounds sweet!!
Mark
Yorba Linda Cal.
  • kano
  • Not Another Bloody Limey!
20 Feb 2009 18:46 #266620 by kano
Replied by kano on topic Gunson Color Tune AVI Clip....
geeze now i gotta buy one of these.
12mm or 14mm omr?
sounds good happy yet lol?:cheer:
20 Feb 2009 18:50 #266622 by timebomb33
Replied by timebomb33 on topic Gunson Color Tune AVI Clip....
sounds good and the motor is very responsive with those small carbs on you did the smart thing and didn't go to big with them which is a comman mistake some people think if some is good,lot's is better not always the caSE dave you will find those 29mm carb's will definitly be an awesome fit for your bike by the way have i mentioned this before your bike is incredable and sir you should be very proud of your self onsuch an amazing transformation
I THINK MY POWERBAND BROKE
  • eddiem
  • KZR FLAG RELAY CARRIER #63
20 Feb 2009 21:53 #266681 by eddiem
Replied by eddiem on topic Gunson Color Tune AVI Clip....
always wondered about that color tune Thankz for posting that OMR might have to look into that
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Old Man Rock
  • Topic Author
21 Feb 2009 06:33 #266745 by Old Man Rock
Replied by Old Man Rock on topic Gunson Color Tune AVI Clip....
Kano... B8ES plugs are 14mm.... You can order other sizes of threading (Color Tune) and they have adapters as well...
Once I Morgan synch, I want to go through the pilot adjustment one more time. In reading the literature, you want to adjust just where the flame goes from yellow to blue. It's stated at this point your still a little on the rich side compared to being lean. Then I'll keep an eye on the plug color to obtain that nice tanned brown color....
Obviously this has me a little spooked due to a brand new motor where I'd rather be on the rich side for now....
Anyhoot, nice tool, made one hell of a difference to a carb noob as myself.... hlol
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
  • Topic Author
21 Feb 2009 06:56 - 21 Feb 2009 06:57 #266749 by Old Man Rock
@ TB
didn't go to big with them which is a common mistake some people think if some is good,lot's is better not always
Most definitely....I'm totally with you there brother ;)
While doing my carb research on what I had in mind for performance, throttle response, driving patterns and in considering my age & riding style, I didn't need to go any larger.
In speaking with Larry C and Buzz over at Dynoman.... After stating the above mentioned variables, especially age and riding style they both stated the exact same thing.... Whoa talk about being spooky... Almost exact word for word replies... And now you say the same where these 29mm where the ideal choice....
As mentioned many times now, don't care if I'm off the line first for not drag racing this bike nor do I care if I gain an extra 10mph on the high range for at my age, I just don't see myself going over 120mph.
Too much to loose to be so reckless at this phase of life...
With my choice of piston kit (1015cc), camshaft (.365) and carb selection (29mm), I will have an extremely strong running motor with exceptional low to mid range response and performance, just where I want it....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Feb 2009 06:57 by Old Man Rock.
21 Feb 2009 07:08 #266756 by arai59
Replied by arai59 on topic Gunson Color Tune AVI Clip....
Great post ! I'm with Mark on this too........sounds beautiful.
  • TeK9iNe
  • What did you do!?!
21 Feb 2009 07:13 #266758 by TeK9iNe
Replied by TeK9iNe on topic Gunson Color Tune AVI Clip....
Yeah man, awsome post!
Always wanted to see one of those in action...
Wonder if it can be used to tune at high/higher throttle positions?..?
Cheers B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
21 Feb 2009 11:21 #266824 by HerrDeacon
Replied by HerrDeacon on topic Gunson Color Tune AVI Clip....
That's really cool OMR, thanks for posting that. Where did you get yours and how much do they run? May have to pick one of those up this summer.
  • Old Man Rock
  • Topic Author
21 Feb 2009 13:00 #266845 by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
21 Feb 2009 14:07 #266854 by HerrDeacon
Excellent, thanks.
