Somebody Blew It
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Somebody Blew It
04 Jan 2024 22:51
#893605
Making way for APE cylinder studs:
photos.app.goo.gl/iFEmMyh9oyWMW5xK6
1982 KZ1100-A2/1170 sleeper 😀
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
05 Jan 2024 05:49
#893615
Is that where the clutch basket goes?  Can you install the clutch basket after the cases are together?  I've never done this, but I have the impression the basket needs to be installed first?
My dad's '74 Z1
'00 ZRX1100
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jan 2024 06:48
#893619
No the primary gear won't clear the case.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jan 2024 06:49
#893620
Good job, proud of you.
  • Mikaw
  • Mikaw's Avatar
05 Jan 2024 07:47
#893623
Personal preference for me is to use a thread chasers to clean the smuts out. I have found bolts to be sloppy when threaded into hole cleared with a tap.
The following user(s) said Thank You: daveo, hardrockminer
  • daveo
  • Premium Member
  • Premium Member
05 Jan 2024 08:36
#893628
Is a chaser able to extend thread length deeper into the hole, or is a tap necessary to do that?
  • daveo
  • Premium Member
  • Premium Member
05 Jan 2024 08:54 - 05 Jan 2024 09:51
#893632
When the 92027-1284 collar is removed from the shaft there is sufficient clearance for the clutch housing to be inserted at an angle into the case.
Is this not the case with other motors?
Assembly Vid:
photos.app.goo.gl/U5oZmPtMk6BuxzCm9
Last edit: 05 Jan 2024 09:51 by daveo.
  • Mikaw
  • Mikaw's Avatar
05 Jan 2024 08:57
#893634
No. They just chase/clear threads. If new are needed you need a tap. Flat bottoming type on blind holes
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jan 2024 08:59
#893635
I've tried but no go. I'd be careful not to thread the studs in too far. I'd test with the barrels and head to be sure you'll have enough threads for the top hat nuts.
  • Mikaw
  • Mikaw's Avatar
05 Jan 2024 09:02
#893637
On the Z/Kz up to 1980 the center of the clutch is integral and no way to tip it in behind the case. Clutch hub must be installed before cases are mated. Good to find that is different on the “J”
  • daveo
  • Premium Member
  • Premium Member
05 Jan 2024 10:13
#893644
CS900K studs were installed in the 82 motor.  Each cylinder stud firmly seats against the hole bottom when tightened as specified.
www.aperaceparts.com/tech/cs10mm.html
  • daveo
  • Premium Member
  • Premium Member
05 Jan 2024 10:16
#893646
Short assembly video:
