Crankshaft Assembly Question
- zed1015
Re: Crankshaft Assembly Question
24 Mar 2023 08:49Not at all accurate enough and wouldn't show up any rod twist etc.
- daveo
24 Mar 2023 09:01Not at all accurate enough and wouldn't show up any rod twist etc.
Anybody have a 18mm rod indexing rod available to borrow/rent?
1982 KZ1100-A2/1170 sleeper 😀
24 Mar 2023 09:18Not wanting to "bring things down" but given that you appear to have already made the purchase and it has been welded, are you not "shutting the stable door after the horse has bolted"Not at all accurate enough and wouldn't show up any rod twist etc.
The following user(s) said Thank You: Nessism, daveo
24 Mar 2023 11:13Not wanting to "bring things down" but given that you appear to have already made the purchase and it has been welded, are you not "shutting the stable door after the horse has bolted"Not at all accurate enough and wouldn't show up any rod twist etc.
Agree. Ignorance is bliss.
If forced, though, McMaster sells 18mm rods. You have to pay attention to straightness, because some are more accurate than others.
The following user(s) said Thank You: daveo, Wookie58
- daveo
24 Mar 2023 21:00 - 24 Mar 2023 21:46
Last edit: 24 Mar 2023 21:46 by daveo.
- daveo
24 Mar 2023 21:09 - 25 Mar 2023 06:05
McMaster Carr was out of stock last check.
17.99 mm O.D. tube spins around smoothly by hand with no perceived play.
Last edit: 25 Mar 2023 06:05 by daveo.
The following user(s) said Thank You: Street Fighter LTD, Wookie58
- daveo
24 Mar 2023 22:23 - 25 Mar 2023 23:50As I understand, a rod is straight if it rolls smoothly on a flat surface without bumping.Not wanting to "bring things down" but given that you appear to have already made the purchase and it has been welded, are you not "shutting the stable door after the horse has bolted"Anybody have a 18mm rod indexing rod available to borrow/rent?Not at all accurate enough and wouldn't show up any rod twist etc.
Brief video:
photos.app.goo.gl/QDYuBiiUaVW7VGza9
Thanks zed1015
Email in profile
Last edit: 25 Mar 2023 23:50 by daveo.
- daveo
26 Mar 2023 16:21 - 28 Mar 2023 06:23
Last edit: 28 Mar 2023 06:23 by daveo.
29 Apr 2023 10:09 - 29 Apr 2023 10:12
Daveo, we are about to jump down a welded crank rabbit hole. The CSR I recently bought had a #1 piston blown, I was hoping I could save the bottom end. I pulled it apart this week and not sure if I’m happy or cursed. The crank is welded. I’m starting the process to find out if a welded crank can be repaired. #1 rod is junk.
Last edit: 29 Apr 2023 10:12 by Mikaw. Reason: Photos
- daveo
29 Apr 2023 17:16
I think that crank is toast, and replacement is the only reasonanble option.
Once welded there may be no going back.
30 Apr 2023 07:17Falicon took mine apart with no extra fees and did the Supercrank thing to it .
Of course this is ancient history. Dont know if anyone today would be willing to do it .
DD
30 Apr 2023 07:47
Gardner Racing Concepts
is still doing them. Looks like they do good work.
Page · Motorcycle Repair Shop
1373 Bangor Rd, Ellsworth, ME, United States, Maine
+1 207-664-0377
grc.cranks@yahoo.com
Always open
Price Range · $$$
+1 207-664-0377
Always open
Price Range · $$$
Attachment not found
