Crankshaft Assembly Question
Re: Crankshaft Assembly Question
21 Mar 2023 17:24
- daveo
21 Mar 2023 19:18 - 23 Mar 2023 01:36
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 23 Mar 2023 01:36 by daveo.
- daveo
21 Mar 2023 19:28 - 23 Mar 2023 08:40Here is a real Falicon
KZ 1000 crank
Ultra lite Supercrank
Round journals have been cut to porkchop 900 style to lighten
Then journals are knife edged to cut thru oil mist and air
Whole thing is highly polished
All the normal crank work to rods ,bearings, welding , truing, indexing and of course magic dust LOL
Imagine the piles of dust it took to make that crank, and the ones left behind ever since.
Last edit: 23 Mar 2023 08:40 by daveo.
- daveo
22 Mar 2023 12:46 - 23 Mar 2023 01:29
Last edit: 23 Mar 2023 01:29 by daveo.
- daveo
22 Mar 2023 14:04 - 23 Mar 2023 00:01I suspect there is a "plan" festering for this gem - "go on" you call tell us, we won't tell Mrs "O"My latest stash addition for some presently unknown future purpose:
I have no idea, but she already knows.
Last edit: 23 Mar 2023 00:01 by daveo.
- daveo
22 Mar 2023 15:02 - 22 Mar 2023 15:03
Last edit: 22 Mar 2023 15:03 by daveo.
- daveo
22 Mar 2023 15:21 - 22 Mar 2023 23:53
The two checks I feel capable of doing:
#5 Thrust Bearing Clearance
...and
Rod Side Clearance
Bearings feel smooth
...and
Rod Side Clearance
Last edit: 22 Mar 2023 23:53 by daveo.
- Dr. Gamma
22 Mar 2023 16:22
The very last Falicon Supercrank I had done I went with polished stock rods. I wish I would have had them bush the small end of the rods.
With all the compression I run in that motor I did have some minor galling in one rod!!! Could of Would of Should of!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: daveo, Dragbike_Mike
- daveo
22 Mar 2023 17:12 - 23 Mar 2023 09:03The very last Falicon Supercrank I had done I went with polished stock rods. I wish I would have had them bush the small end of the rods.
Crankshaft appreciation 101:
en.wikipedia.org/wiki/Crank_(mechanism)
Last edit: 23 Mar 2023 09:03 by daveo.
22 Mar 2023 20:01
Here he is talking about honing the rods to proper clearances.
www.facebook.com/photo/?fbid=67270282132...=pcb.672702974653374
- daveo
24 Mar 2023 08:44 - 24 Mar 2023 08:52
Optical Rod Indexing. Any thoughts-opinions regarding efficacy?
Beats locating a proper 18mm steel rod, and provided purpose for some old Lego's.
Last edit: 24 Mar 2023 08:52 by daveo.
24 Mar 2023 08:49
Looks good to me, why over complicate things. I don't know how many splines are on each crank section but I would imagine if you were 1 out, it would be obviously apparent
