Piston Hole Kz1000LTD 1982
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Piston Hole Kz1000LTD 1982
28 Dec 2023 18:48
#893246
For reference.  Drill-driven output shaft:
photos.app.goo.gl/eTk9hc1Rty5PnviD6
With crankshaft removed.
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: SWest, Mikaw, cartal, Wookie58
  • cartal
  • cartal's Avatar Topic Author
29 Dec 2023 04:15
#893273
Thank you guys (yet again) for the replies. As I have already closed the cases, I feel a bit uneasy to try to connect the drill to the output shaft. I fear for the new cam chain. I´ve tried, but cannot figure out how to do such connection, and I definitely don´t spin it fast enough.
I will take your picture as reference that all my parts are correctly installed, and go from there.
Cheers.
C.
  • zed1015
  • zed1015's Avatar
29 Dec 2023 07:10
#893277
If the clutch plates are removed the gearbox and clutch hub will spin but the outer basket and crank are isolated so can't be driven by the gearbox.
If you lay the engine on some wooden blocks on the clutch side you haven't got gravity working against you and the balls will roll outwards much easier with little rotational force and once you are in second the rest of the gears can be selected without having to spin the output shaft.
The following user(s) said Thank You: daveo, Mikaw, Wookie58
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
29 Dec 2023 12:46
#893285
CAUTION:  What may be worthy of worry is for the life span of your drill, which may be dramatically shortened during this process.
The following user(s) said Thank You: cartal
  • cartal
31 Dec 2023 05:50 - 31 Dec 2023 17:54
#893318
I may regret this later; but I looked and reviewed everything in the gearbox, and it looks OK. I could not find a way to adapt a drill to the shaft, so I´ve decided to move on. I have a solid first gear and a nice neutral. I´ll cross my fingers, and hope it works!
So, as I move on; engine is now "closed", and everything looks neat. New large bolts, and reused all the rest. No threads were damaged in the process... so we are ready to install the pistons now.
Happy to see some movement. Pics for reference, and for expert advice on any mistakes I may have made.
Cheers.
C.
Last edit: 31 Dec 2023 17:54 by cartal. Reason: pic ordering
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
31 Dec 2023 09:54 - 31 Dec 2023 10:27
#893328
Be sure to change out the old clutch push-rod o-ring while there is open access to it.
Ps.  It seems to help for viewing when a space is created between images as they are posted.
Last edit: 31 Dec 2023 10:27 by daveo.
The following user(s) said Thank You: Street Fighter LTD, cartal, howardhb
  • cartal
31 Dec 2023 17:53
#893365
Thank you. Had no idea there was an o-ring in there. Good tip for the pics. Will do now.
Happy new year!
  • cartal
01 Jan 2024 12:19
#893397
Pistons in place. Of course, I did drop a cotter pin into the oil pan, and had to take it off to get it. Of course it was the first one :-(
Anyway; all done now. Ready to get the cylinder block on. I have a question:
I don´t see any o-rings in the bottom of the cylinder block, just the gasket. Is that right?
I´m looking at this image, and I don´t see any. The manual says nothing about them.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
01 Jan 2024 17:38 - 02 Jan 2024 16:18
#893411
No O-rings at the bottom, but 2 x 92043 locator dowels at the front outside studs...
Ps.  BTW, I have a couple extra brand new clutch-rod o-rings just laying around.
...or a-round?
Last edit: 02 Jan 2024 16:18 by daveo.
  • cartal
03 Jan 2024 07:47
#893492
Thank you for the offer. The cost of postage and then customs, makes it impossible, though. This has gone out of hand!
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 Jan 2024 08:48
#893505
Where would one tiny o-ring in an envelope need to be mailed?
  • cartal
05 Jan 2024 15:48
#893667
Madrid, Spain. Are you in the US?
