Cylinder Head Removal - first time and could use some guidance
  • hardrockminer
  • hardrockminer's Avatar
Re: Cylinder Head Removal - first time and could use some guidance
05 May 2022 04:29
#866646
It looks like about 2 degrees advanced.  Should not be a problem.  Have you run the engine?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
05 May 2022 14:31 - 05 May 2022 14:32
#866660
How far does 1 tooth move the mark (sometimes if everything is lined up perfectly as you tension the chain the cams rotate) which can leave you a tooth out
Don´t know the 650 specs but on Z1/KZ900
15 tooth on crank and 30 tooth on cam sproket = gear ratio 2 to 1 = 48 degrees (2 tooth) on crank are 12 degrees (1 tooth) on cam sprocket.
As hardrockminer supposed, your TDC is 5 degrees advance on the crank = 2-3 degrees on cam = no problem.
Without a degree wheel and adjustable cam sprockets you can´t adjust the cam chain wear/stretch.
Last edit: 05 May 2022 14:32 by Scirocco.
The following user(s) said Thank You: jekyllman
  • jekyllman
  • jekyllman's Avatar Topic Author
05 May 2022 16:45
#866668
Thanks everyone. Just eyeballing it the difference equates to around 1/4 tooth on the cam sprocket, at most. I haven't fired it up yet. Hopefully this weekend. Just got the valve cover back on last night.
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
