Porting KZ heads
- DoctoRot
Re: Porting KZ heads
26 Mar 2020 19:10
I recently discovered Schumann Motor Works. out of Milwaukie OR. He specializes in vintage Japanese cylinder heads. He is doing a full custom valve train for my kz750 including a port and polish. Very reasonable prices.
The following user(s) said Thank You: SWest, Mikaw
26 Mar 2020 21:01
Might as well get started on this one.
- M_a_t_t
28 Mar 2020 09:17 - 28 Mar 2020 10:09
Kind of on topic, I am working on a new engine for my car and thought I would try porting and gasket matching on it. Its a Suzuki G13BB which is pretty common so I can get replacement manifolds cheaply (head as well if need be) if I ruin it, but is this something I should still avoid? I am trying to get more performance out of it, but not really a "track machine/drag car".
Some of you have said it can do more harm than good. Is that worse than stock/original or just not really any better than it was?
EDIT:
I should add, I'm trying to use this build as a learning experience as much as I can.
EDIT:
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
Last edit: 28 Mar 2020 10:09 by M_a_t_t.
28 Mar 2020 10:25
There is a video about matching manifolds to the gaskets and heads. Good info. He also says polishing the intakes can be a mistake. They need to be a little rough for atomization. In two strokes it's a different matter.
