Engine oil surge issue
- Bozo
- Ride it like u stole it
Re: Engine oil surge issue
15 Dec 2016 17:09Street Fighter LTD wrote: Kawasaki Doesnt Hate You BOZO
Kawasaki Is Just testing Your Faith
Dave![]()
In that case I'll buy a Harley tomorrow
just kidding guys :whistle: :whistle:
15 Dec 2016 18:38
:ohmy: :woohoo:
- Bozo
17 Dec 2016 22:51
Well after a spirited ride on Sunday the oil surge is no longer there. As you know this was at the expense of the oil relief valve. I should get away without it but if I was in a cold climate or no regular servicing I would not risk it to prevent hydraulic lock on the oil pump.
18 Dec 2016 05:14
How does that happen?
- Bozo
18 Dec 2016 14:48swest wrote: How does that happen?
I assume you are referring to the hydraulic lock?, I don't know but that's the only reason that relief valve is there, if for some reason the oil pressure gallery gets blocked the oil has no-where to go which would cause he oil pump to lock and bits flying everywhere, unless the relief valve opens.
18 Dec 2016 16:35
I doubt that would happen. Must be another reason for it being there.
- Nic
09 Jan 2017 21:26
Well FFS, I've only just got my KZ900 going n have been breaking it in somewhat, today I gave it some stick in 1st and the oil light came on, looks like I'll be putting in a gate soon :ohmy:
- Bozo
10 Jan 2017 03:32Nic wrote: Well FFS, I've only just got my KZ900 going n have been breaking it in somewhat, today I gave it some stick in 1st and the oil light came on, looks like I'll be putting in a gate soon :ohmy:
Yep thats the culprit, I assume the oil level on your Z is full? :pinch:
- Nic
- Bozo
15 Jan 2017 03:56Brilliant, you'll save your engine from a heart attack, usually I found the out crankshaft bearing (the removable one) was the first to sufferNic wrote: Gate fitted, no more oil light, works well.
- Nic
15 Jan 2017 14:56Thanks mate, I had a black motor Z1 back in the day n never had this oil light problem. Anyway, she's good now.Bozo wrote:Brilliant, you'll save your engine from a heart attack, usually I found the out crankshaft bearing (the removable one) was the first to sufferNic wrote: Gate fitted, no more oil light, works well.
