Low compression, oil out the breather. kz900/1000
Re: Low compression, oil out the breather. kz900/1000
29 Jun 2016 10:26
#733272
[quote="MadShad" post=733253..................................The clutch let go right at 6k rpm, started slipping.
This is my 4th Kawasaki, and I've put clutch springs in ALL of them. :unsure:[/quote]
That does not seem normal to me. Exactly what oil are you using in the engine? Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2016 11:04
#733279
It's somebody else's work and has sat for a while. I'd inspect the plates, clean and oil them.
  • MadShad
  • MadShad's Avatar Topic Author
29 Jun 2016 11:17
#733284
Rotella conventional 15 40 in most, 10w30 in one.
I have friction disks on the shelf if I need them, I've just used ebc springs in all of them for $10 a set, seems to work great.
All of my bikes were purchased either non running or running poorly, most have set for years. This one had been sitting for at least 5 years.
All had what looked like oem springs.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2016 11:25
#733285
I've never worn out a set of springs.
  • MadShad
01 Jul 2016 11:40
#733513
All I can say is that the new clutch springs are in and the problem is solved. Put 180 miles on it yesterday driving to a jap bike junkyard. Picked up an oil cooler to play with and scored a 140mph speedo to replace my 80mph one.
Break in miles are done, oil and filter is changed, ignition timing is set, carbs are rejetted, needles are adjusted.
The bike runs great, no leaks and the bike pulls hard!
Very happy with the result!
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jul 2016 11:54
#733516
Good job. B)
  • loudhvx
  • loudhvx's Avatar
01 Jul 2016 12:09
#733519
Great to hear the motor is alive! B)
With all of the clutch slippage you've experienced, are you sure you are not overfilling the oil? That always makes my bikes slip. But as long as there is a good size air bubble at the top of the sight glass, when on the wheels (not center stand), vertical, I usually have no problems.
  • MadShad
01 Jul 2016 12:26
#733525
Yep since this is my 4th Kaw with slipping clutched I've exhausted all other options, overfilled oil, wrong oil, adjustment (both method s depending on actuator type), friction disk thickness, steel plate orientation, polishing fingers on clutch basket and steel plates, dragging clutch cable, clean and relube actuator,
The whole enchilada....
Springs fixed it 4 out of 4 times.
  • KZB2 650
  • KZB2 650's Avatar
01 Jul 2016 14:08
#733535
Good to hear ..... I'm a strong believer on replacing clutch springs..... I could feel the difference in strength by pressing on the new ones then the old when I replaced mine and like you no more slip.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jul 2016 14:21
#733536
I can't comment on the smaller fours but My clutch always was to stiff no matter what I did. Never had a slip issue. Finally copied Dave's mod Broke cables once a year or so. I think I solved that problem.
. kzrider.com/forum/2-engine/601798-clutch-actuator-mod
  • loudhvx
  • loudhvx's Avatar
02 Jul 2016 08:38
#733599
MadShad wrote: Yep since this is my 4th Kaw with slipping clutched I've exhausted all other options, overfilled oil, wrong oil, adjustment (both method s depending on actuator type), friction disk thickness, steel plate orientation, polishing fingers on clutch basket and steel plates, dragging clutch cable, clean and relube actuator,
Ok, well as long as it works! Sorry, you've probably detailed all of that before... I post on a lot of similar threads :S
Can't wait to see the finished pics!
  • loudhvx
  • loudhvx's Avatar
02 Jul 2016 08:41
#733600
swest wrote: I can't comment on the smaller fours but My clutch always was to stiff no matter what I did. Never had a slip issue. Finally copied Dave's mod Broke cables once a year or so. I think I solved that problem.
The 550 clutches are very light from the factory. If it's stock and stiff, it's usually the cable getting some drag. The factory cable is much better than the aftermarket ones I tried.
I have an actuator taken apart and ready to weld/drill after seeing your post. Just to experiment with.... like I said, the 550 clutches are pretty light already.
