Tips for ring installation
- Dr. Gamma
Re: Tips for ring installation
18 May 2016 14:30Yetanotherkzrider wrote: Yeah. Just went through a can of permatex and didn't even put a dent in the gasket.
Just go and buy yourself a can of paint stripper and brush it on. Its the same as what they sell as gasket remover, and a lot cheaper!!!! Get the one with all the warning labels on the can. It works the best!!!
1986 RG500G 2 stroke terror.
- Yetanotherkzrider
19 May 2016 08:13
Exactly what I did. Ithe also took the carbon right off of the pistons!
Dr. Gamma wrote:Yetanotherkzrider wrote: Yeah. Just went through a can of permatex and didn't even put a dent in the gasket.
- Yetanotherkzrider
19 May 2016 08:16
I'll definitely drop the pan. Accidentally dropped one of the stupid rubber dampers from the bottom roller down in there. No telling what kind of damage it could do.
KZB2 650 wrote: Did you drop the pan? Rags can keep most of the gasket and junk out but I dropped too much in and flushed the hell out of the motor through the removed pan and by flipping it over a few times. Used spray brake cleaner, wd 40, a little gas and maybe some carb cleaner although kerosene would be safer by far than the gas...... after 65,000 miles I bet there is a ton of sludge in there. I replaced the screen on the oil pump too but that might not be needed on yours.
The following user(s) said Thank You: KZB2 650
- Yetanotherkzrider
19 May 2016 08:17
What's the purpose of flushing with diesel?
swest wrote: I scrape it. A heat gun helps. Put in the new rings. I flush the engine with diesel.
- missionkz
19 May 2016 18:26 - 19 May 2016 18:27That is pretty much an old school 1960's, oil change ritual.Yetanotherkzrider wrote: What's the purpose of flushing with diesel?swest wrote: I scrape it. A heat gun helps. Put in the new rings. I flush the engine with diesel.
Modern oils and fuels probably don't really need to be flushed with diesel oil/ fuel.
But some old guys still do it.
Especially after a fresh rebuild and gasket scraping exercise!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 19 May 2016 18:27 by missionkz.
19 May 2016 18:47
Exactly. At each step I'll pour some to wash away the pieces. It's cheap and a good cleaner.
- Yetanotherkzrider
19 May 2016 19:07 - 19 May 2016 19:12
I dropped the oil pan and gave it a shot, worked pretty well and I got everything pretty clean. Also got my cylinder block back. Now I'm just waiting for the mail so I can get it all back together.
Last edit: 19 May 2016 19:12 by Yetanotherkzrider.
19 May 2016 19:14
Once I have it all together I'll pour about 1/4 gallon in with the drain plug in. I open the drain and watch the crap I missed come out. I also use a 1 gallon oil container cut out on one side. Easy to see what came out. I then put in my new filter and oil.I change it in about 500 miles.
19 May 2016 20:10daveo wrote:missionkz wrote: so satisfying.... compared to trying to do it with all the nutty contraptions, hose clamps, beer cans, plastic wire ties (you name it) I've seen them all.
First attempt, and was a joy too. A cheap one... :lol:
The black plastic strip is slick. It gets pressed down the piston by the bottom of the cylinder sleeve as it presses on the edge of the strip. The rings pop free inside the sleeve where they should, with the gaps locked in their proper positions. You don't get that using fingers to compress the rings.
The following user(s) said Thank You: Yetanotherkzrider
19 May 2016 21:12
I keep telling myself I'm going to get some of the proper hose clamps, shim stock, etc, and make some ring compressors, but when the time comes I always wind up pinching in the rings with my fingers and a plastic white stick during install. Never broke a ring yet (knock on wood).
- Yetanotherkzrider
19 May 2016 21:50
Nice! Pretty sure I have some clamps and plastic laying about, so I'll probably try that. Thanks to everyone who participated in this thread I think I'll get her together just fine.
- bluej58
20 May 2016 04:25Yetanotherkzrider wrote: I dropped the oil pan and gave it a shot, worked pretty well and I got everything pretty clean. Also got my cylinder block back. Now I'm just waiting for the mail so I can get it all back together.
If you haven't done so already , wipe some motor oil on those fresh honed cylinder walls to keep them from rusting while you wait for the rings
78 KZ1000 A2A
