So, how screwed am I? - Exhaust cam
  • 80B4
  • 80B4's Avatar
Re: So, how screwed am I? - Exhaust cam
19 Apr 2016 10:35
#721807
swest wrote: I don't think so. :whistle:
"I don't think so " about what?
1980B4 1000
1978 Z1R
1978 B3 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Apr 2016 10:52
#721815
Motor swap or oil passages.
  • Kapahulu
  • Kapahulu's Avatar
19 Apr 2016 11:49 - 19 Apr 2016 11:49
#721822
After changing the cam, it wouldn't hurt to run it with fresh oil for a little while, drain and put new oil again. Some might think it's a waste but it won't cost much and you might still find bits coming out on the second oil change.
2strokeworld.com
Last edit: 19 Apr 2016 11:49 by Kapahulu.
  • 80B4
  • 80B4's Avatar
19 Apr 2016 12:49
#721838
swest wrote: Motor swap or oil passages.
These engines are very cheep to buy. I've paid as little as $25 for a b1 engine. I have 4 of these engines.
It would be easy to see if the oil passages are full of glitter, When the oil filter cover is removed to change the filter, take a long q-tip and swab the oil passage locate at about 10 o'clock. No glitter and you are good to go. If the q-tip comes out of that oil passage with metal particles, everything is contaminated. These engines are full of needle and roller bearings. It doesn't take much to screw them up.
1980B4 1000
1978 Z1R
1978 B3 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Apr 2016 12:59 - 19 Apr 2016 13:00
#721841
If the oil filter is doing it's job, there should be no problem. I would and do change the oil twice just for GP. Glad to hear you engines are plentiful and cheap. mine aren't. :dry:
Last edit: 19 Apr 2016 13:00 by SWest.
  • KZB2 650
  • KZB2 650's Avatar
19 Apr 2016 14:24
#721867
Kapahulu wrote: After changing the cam, it wouldn't hurt to run it with fresh oil for a little while, drain and put new oil again. Some might think it's a waste but it won't cost much and you might still find bits coming out on the second oil change.
I like that idea (filter too) ......... After I did the 700 kit I changed the oil at either at 50 or 100miles (have it wrote down some where but I forget exactly) ...... then at least twice more before I did the final one at 600....... like you say some won't agree but I felt it was cheap insurance..........had a lot of STP and assembly lube to get rid of the first time but mostly wanted to get the glitter (cyl walls breaking in) out and keep the motor clean.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Topper
  • Topper's Avatar Topic Author
19 Apr 2016 15:13
#721883
Two oil changes it is! My replacement cam shipped today. I'll keep you all posted.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Topper
30 Apr 2016 15:41 - 30 Apr 2016 15:46
#723829
Well damn. It happened again. I got a new cam and swapped it out. Pulled the oil pan and oil pump. Cleaned the gunk out of the pan (not much metal debris but lots of sludge) and inspected the pump (no scoring or damage). Checked valve clearance, etc.
This time I was super careful about putting that tach gear in. I did it while the valve cover was off so I could see what was going on. I made sure the tach gear and cam were meshing, turned it over by hand a few times to make sure the tach gear was turning. Everything looked good.
Buttoned everything back up and started it.Tachometer was working. I hopped off to look around and check for oil leaks. When I looked up, the tach had stopped working.
I cut the bike off immediately. Pulled the tach gear out and a bunch of metal shavings came out again. WTF am I doing wrong??!!
Photos of my cam swap are below in case they're helpful to anyone.
Setting to top dead center.
Attachment 14620559082762[1].jpg not found
Marked the cam gear and chain with red nail polish to aid in reassembly
Attachment 14620559081850[1].jpg not found
Just keeping the chain from falling down.
Attachment 14620559082541[1].jpg not found
Gunk in the oil pan.
Attachment 14620559349685[1].jpg not found
Inside the oil pump.
Attachment 14620559347343[1].jpg not found
New cam in place.
Attachment 14620559347704[1].jpg not found
1979 KZ750 Twin
Last edit: 30 Apr 2016 15:46 by Topper.
  • missionkz
  • missionkz's Avatar
30 Apr 2016 16:28
#723834
With out re-reading the whole thread.... did you also replace the drive gear with the new cams?
how about the drive gear, shaft bushing in the head boss?
I'm at a loss.... I've yanked that thing in and out dozens of times on dozens of bikes and never had a fouled one...????
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Topper
30 Apr 2016 17:19
#723838
This started with a leak at the tach cable. Replaced tach seal, somehow shredded cam. Replaced cam. Shredded it again.
Installing the tach gear should be super simple. I can't figure out what i did wrong.
1979 KZ750 Twin
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2016 17:31
#723839
New drive gear and holder? Is the stop in the head munged up?
  • Topper
30 Apr 2016 18:46
#723844
New holder (guide) yes. The gear looked fine so i rused it.
I don't think there's a stop in the head. None that i could see on the parts diagram anyway.
1979 KZ750 Twin
