- Thank you received: 133
So, how screwed am I? - Exhaust cam
- Topper
Attachment 14608257374070[1]-2.jpg not found
I honestly don't know how I did this. Didn't feel like I was forcing anything, never heard a grinding noise, nothing.
So my question now is just how screwed am I here? I clearly need a new exhaust cam shaft. My concern is all the little metal bits that got torn off. I removed a number of them with a pick and a magnet, but I'm sure there's lots more in the oil.
Am I looking at a complete engine tear down and rebuilt because of this? Or will my filter have kept my engine reasonably safe?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Thank you received: 2063
New Cam or electric tach.
Not really familiar with KZ twins , but I would pull pan and pull off pump and inspect pump internals. That should tell you somethings, then flush out all oil galleries with a lite solvent and air and collect what comes squirting out to have enough information to decide how far you need to go.
OR
Just tear the whole thing down to be safe and dont take any short cuts
- Thank you received: 2823
- bountyhunter
- Thank you received: 337
- Topper
1979 KZ750 Twin
- Thank you received: 2749
- RonKZ650
- Thank you received: 240
- 80B4
- Thank you received: 105
1980B4 1000
1978 Z1R
1978 B3 750
- KZB2 650
- Thank you received: 265
swest wrote: I wouldn't. The strainer will catch most of it. I would inspect the oil pump. It may be scored inside.
At least drop the pan and clean it out..... betting the pump strainer has metal stuck in it..... I replaced mine (strainer)...... removing 38 years of sludge stuck the bottom of the pan will do the motor and oil changes good anyway.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Topper
1979 KZ750 Twin
