So, how screwed am I? - Exhaust cam
  • Topper
  • Topper's Avatar Topic Author
16 Apr 2016 10:14
#721219
So I replaced the tach seal and o ring on my 79 KZ750 ( kzrider.com/forum/2-engine/601914-trick-...installing-tach-gear ) to fix a leak. Leak was fixed, but the tach wouldn't work after I replaced the seals. Engine started up but the tach wouldn't work. Now I see why.
Attachment 14608257374070[1]-2.jpg not found
I honestly don't know how I did this. Didn't feel like I was forcing anything, never heard a grinding noise, nothing.
So my question now is just how screwed am I here? I clearly need a new exhaust cam shaft. My concern is all the little metal bits that got torn off. I removed a number of them with a pick and a magnet, but I'm sure there's lots more in the oil.
Am I looking at a complete engine tear down and rebuilt because of this? Or will my filter have kept my engine reasonably safe?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: So, how screwed am I? - Exhaust cam
16 Apr 2016 10:34
#721221
Ouch :ohmy:
New Cam or electric tach.
Not really familiar with KZ twins , but I would pull pan and pull off pump and inspect pump internals. That should tell you somethings, then flush out all oil galleries with a lite solvent and air and collect what comes squirting out to have enough information to decide how far you need to go.
OR
Just tear the whole thing down to be safe and dont take any short cuts
Dave B) B) B)
  • Nessism
  • Nessism's Avatar
16 Apr 2016 10:37 - 16 Apr 2016 10:38
#721223
You can try flushing the engine after dropping the sump cover. Not sure it's necessary. The oil filter will catch the bits as they are sucked up by the oil pump. You might want to pull the sump cover and clean that out when replacing the camshaft. No way i'd tear the engine apart just because of the damage shown.
Last edit: 16 Apr 2016 10:38 by Nessism.
  • bountyhunter
  • bountyhunter's Avatar
16 Apr 2016 12:07
#721233
I'd drop the pan and check for debris. Clear if found. Change oil and filter. Camshafts are pretty easy to change. I see "tear downs" on ebay sometimes where they sell every piece from an engine. You could get a canshaft and tach gear that way. Online dismantlers are the other option.
  • Topper
16 Apr 2016 14:17
#721257
Yeah there are some cams in the 50-150 range. Sounds like the consensus is that i don't necessarily have to tear the engine down. That's a relief.
1979 KZ750 Twin
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Apr 2016 18:13
#721303
I wouldn't. The strainer will catch most of it. I would inspect the oil pump. It may be scored inside.
  • RonKZ650
  • RonKZ650's Avatar
16 Apr 2016 20:04
#721326
I've seen it before. Just change the cam, change oil and filter and you'll be good to go.
The following user(s) said Thank You: PLUMMEN
  • 80B4
  • 80B4's Avatar
16 Apr 2016 20:07
#721329
Any metal that gets past the screen goes through the oil pump before it gets to the oil filter. I would disassemble and clean it. The transmission shafts are pressure lubed and there lots of other passages that will need to be cleaned. You can also look into a motor swap, that may be a cheeper way to go.
1980B4 1000
1978 Z1R
1978 B3 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Apr 2016 20:27
#721335
I don't think so. :whistle:
  • KZB2 650
  • KZB2 650's Avatar
17 Apr 2016 07:07
#721380
swest wrote: I wouldn't. The strainer will catch most of it. I would inspect the oil pump. It may be scored inside.
At least drop the pan and clean it out..... betting the pump strainer has metal stuck in it..... I replaced mine (strainer)...... removing 38 years of sludge stuck the bottom of the pan will do the motor and oil changes good anyway.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2016 07:21
#721387
That's a given. The pan has to come off to get to the pump. It may have scratches in it. They can be taken out with #600 paper.
  • Topper
17 Apr 2016 07:55
#721394
Yep, I'll be sure to remove the oil pan an inspect the pump too!
1979 KZ750 Twin
