gearing
  • z1kzonly
  • z1kzonly's Avatar
Re: gearing
12 Mar 2016 11:48
#715111
First of all, Do you know who built the bike? Was it a drag strip bike with a slick? Or just a cool hot street bike?
Is this thing a KZ 900-1000? looks so in small picture.
With a 17 countershaft! You have 530 chain size. What is the rear wheel from? Another Jap bike, a Harley rim? 17" or 18" diameter.
Need pictures of the rear rim and the offset sprocket and carrier plate with the bearing. Most drag bikes with the big slick or car tire use a 3" offset.
Don't order anything till you know whats going on. If you can find a smaller rear then thats all you need to do.
Go down about 5 or 6 teeth and cut your chain. As long as there is clearance along the way past the swingarm.
Your small avatar picture does not show much.
  • kawi810
  • kawi810's Avatar
Re: gearing
12 Mar 2016 13:27
#715124
first off a 630 means a pitch of 3/4 " a 530 means a pitch of 5/8" .measure your chain than go from there.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 18:10
#715154
As I asked long ago, need pics.
  • PaintWorkz
  • PaintWorkz's Avatar
Re: gearing
13 Mar 2016 08:59
#715207
I use this website calculator for gearing predictions. www.gearingcommander.com/
measure your chain size.....the distance between pins, tire circumference, and just pick your bike from the list, and try different combos.
It will be pricey to buy a new offset front sprocket, if it is not worn just buy a smaller rear to get freeway cruising RPM lower.
your bike in the avatar look like it was a dragbike set up with 1/4 mile gearing and has a small circumference rear tire.....so the RPMs will be high on the freeway.....but fun on the street!
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
The following user(s) said Thank You: goldylox
