gearing
- goldylox
gearing
07 Mar 2016 18:38 - 07 Mar 2016 18:39
When im on the interstate riding my bike is putting out real high rpm will i need to change up my front gear havent checked ot out wat it is but it was set up for drag but now i wana go back to somthi g were i can get away from the high rpm amy suggestions
Last edit: 07 Mar 2016 18:39 by goldylox.
Re: gearing
07 Mar 2016 18:56
16/35. 4000 RPM's at 70 MPH.
- goldylox
Re: gearing
07 Mar 2016 19:20
16/35 do u have any websites and i have a 330 fat tire on back of my bike so ill prob most likly have to call it in 16/35 is the 16 how many teeth on it or wat should i ask for
Re: gearing
07 Mar 2016 19:31
16 tooth front/35 teeth rear.
- goldylox
Re: gearing
08 Mar 2016 19:02
Hey steve realy apreciate the help so i just checked my front and rear and im running on front a 17 teeth with a 4 inch off set and rear im rinning a 46 teeth but i went to bike bandit and stock it was calling for a 15 front and 33 rear and why would they set wat i have on it up like that for any guesses
Re: gearing
08 Mar 2016 19:04
4" off set?
- goldylox
Re: gearing
08 Mar 2016 19:24
Im running a 330 rear wheel so the gear is welded to a cup like unit and it hangs 4 inches away from bike teying to send u a pic but wont let me
Re: gearing
08 Mar 2016 19:33
If that is the bike and you want to ride on the street you may want to get a different swing arm and set up.
- goldylox
Re: gearing
08 Mar 2016 20:04
I was wanting to keep this just only with different gear there is a guy that build these custom sprokets and i just sent him an email to get a 15T build so that i can put that on i like the rear swing arm and tire just will like to ride a lil longer on interstate with out the high rpm
Re: gearing
08 Mar 2016 20:52
It must handle like a truck. More suited for the track. Pics?
- KZ Rat
Re: gearing
09 Mar 2016 04:24
What size chain are you running? You might want to tell the guy building the sprocket what you're trying to do-to keep from accidentally going the wrong direction and gearing the bike even lower.
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
- KZB2 650
Re: gearing
09 Mar 2016 06:55KZ Rat wrote: What size chain are you running? You might want to tell the guy building the sprocket what you're trying to do-to keep from accidentally going the wrong direction and gearing the bike even lower.
True ....if your keeping the 46T rear the 15t front will lower it more ..... you would need a 18T front to lower the rpms (again if keeping the 46T rear)....... and a long low and mean drag racer on the street looks like it might be fun but like Steve says watch the curves.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
