gearing
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
09 Mar 2016 07:05
#714601
15/33 or 15/35 would be stock with a 630 chain and still be fast. 5000 +/- at 70 MPH 16/35 would be about 4000 RPM at 70
A setup like that would be a blast to ride in a straight line like a "Chopper" but would handle like one too. It does have a certain 'Cool" factor. :whistle:
  • goldylox
  • goldylox's Avatar Topic Author
Re: gearing
12 Mar 2016 05:43
#715061
Ok i wana leave the front but change the rear and i wana go to a 40T will that bring it low enough for the interstate
  • goldylox
Re: gearing
12 Mar 2016 05:44
#715062
Cause the front is over 220 for that gear and not willing unless have too
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 06:46 - 12 Mar 2016 06:48
#715071
"Ok i wana leave the front but change the rear and i wana go to a 40T will that bring it low enough for the interstate
Cause the front is over 220 for that gear and not willing unless have too"
Is that $220? It would help if I could read what you're writing. Texting on a phone?
What size chain are you running? What are the teeth counts front and rear?
From what I remember, your bike was geared too low for the FWY. Smaller in the rear will lower the RPM's at speed but cost you off the line acceleration.
If you want to ride a drag bike on the street, all I can say is, that's the cost of doing business.
Last edit: 12 Mar 2016 06:48 by SWest.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 07:10
#715073
Ok I just reread the thread. TMW Going from 46 to 40 would lower the RPM's. 17 on the front? I don't think I could fit one that large in mine. Maybe I could IDK. Being the rear sprockets are cheaper, that sounds like the way to go in case you have to buy another one in the middle. The chain will have to shortened of course.
  • KZB2 650
  • KZB2 650's Avatar
Re: gearing
12 Mar 2016 07:46
#715078
Sounds like a plan but check out the chain when you have it off hopefully its not too worn as you are suppose to always replace both sprokets and the chain in a set...... being a drag bike it may have not had a easy life......... Sounds like you figured out the vibration you were getting with others thinking it was too full of oil?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 07:52
#715079
Larger front and smaller rear seems backwards to me. :unsure:
  • kawi810
  • kawi810's Avatar
Re: gearing
12 Mar 2016 08:08
#715081
the first question what size chain ? 630 or 530 ? a 17 tooth 530 is about the same diameter as 630 15 tooth .when going with a 530 chain you need a larger dia. front so the chain does not rub on the swing arm. 17 - 40 would be a 2.35 ratio.about the same as a 15 -35 is 2.33 ratio in 630 chain size.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 08:23
#715084
Sounds good. The size of chain was and is the question.
  • TexasKZ
  • TexasKZ's Avatar
Re: gearing
12 Mar 2016 08:59
#715092
Perhaps I missed it, but he will need to consider the circumference of that rear tire since is likely is quite different from stock.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: gearing
12 Mar 2016 09:32
#715097
Hasn't been forth coming on questions asked.
  • goldylox
Re: gearing
12 Mar 2016 11:33
#715109
Sorry i am using a cell phone and i am going to go with the 40T on rear first and how can i determine what size chain i have cause i was just going to break it down to make it fit
