Valve clearance/carbon deposit on plugs
  • Nessism
  • Nessism's Avatar
  • Away
Re: Valve clearance/carbon deposit on plugs
29 Apr 2015 15:24
#670017
Restoring clearance on the valves may require moving two shim sizes. You might want to keep this in mind when placing your shim order. Also, after installing a thinner shim make sure to double check the clearance to confirm that you fixed the problem.
  • gcphoto
  • gcphoto's Avatar Topic Author
29 Apr 2015 15:29
#670018
So for the 650 it's more complicated, but I don't need any special tools other than a caliper to measure the shims (assuming the etched measurement is worn off)? I don't want to waste money on unneeded shims so I suppose I'll remove, measure, order then install/remeasure?
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
  • chconger
  • chconger's Avatar
29 Apr 2015 18:15 - 29 Apr 2015 18:19
#670041
gcphoto wrote: I don't want to waste money on unneeded shims so I suppose I'll remove, measure, order then install/remeasure?
Your problem is the "0" clearance valves. The real reading is not likely zero, but some negative number that feeler gauges can't measure.
When you take the shims out, you can measure (or read) what shims you have. But then you will be guessing how much thinner they need to be to start picking up a gap again.
Aside from having a "shim kit" at hand, I can think that if you had just one real thin shim, placed it in a "0" valve, then you will get a reading to math out the real shim it needs.
1977 KZ 1000-A
Last edit: 29 Apr 2015 18:19 by chconger.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Apr 2015 21:30
#670059
That's one way of doing it. I like to have the next sizes down for future use. Odds are you will need one of the smaller ones, perhaps more.
  • bluezbike
  • bluezbike's Avatar
29 Apr 2015 23:22
#670066
It's likely you have to do the valve check twice on the valves that measure 0. As mentioned use a thinner shim than you think to get a positive number as a gap then calculate what you really need as a shim. I would use a decent magnet if you don't have a suction device.
Hth
79 KZ 1000 LTD
  • bluej58
  • bluej58's Avatar
30 Apr 2015 04:13
#670077
If you go to Wiredgeorge's site he has the 77 kz650 shop manual in his downloads on page 5 of the Kawasaki files
www.vintagebikeforum.org/
You will probably have to join to see it though, no big deal
JD
78 KZ1000 A2A
  • chconger
  • chconger's Avatar
30 Apr 2015 08:33
#670110
bluezbike wrote: I.... I would use a decent magnet if you don't have a suction device.
Hth
There is a theoretical risk bringing magnets around engine parts.
In this instance, if a shim becomes magnetized from being in proximity of a magnet, then it will pick up any metal out of the oil and hold on to it, then the cam will swing by and wear on the metal..in theory.
I don't know how big a risk this is in the real world, but I demagnetize any tools I use around the shims & cams as standard practice.
1977 KZ 1000-A
The following user(s) said Thank You: bluezbike
  • bluezbike
30 Apr 2015 13:03
#670143
Did not realize it might be a problem, thank you......what do you do to demagnetize your tools?
79 KZ 1000 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2015 13:22
#670144
Pulling a shim out with a small magnet isn't a problem. If it worries you then you can use tweezers. I for one am not that paranoid.
  • gcphoto
30 Apr 2015 17:35 - 30 Apr 2015 17:36
#670176
This is coming from the guy who made his own shims out of beer cans. :laugh:
'78 KZ650 SR
___________
Last edit: 30 Apr 2015 17:36 by gcphoto.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2015 17:39
#670179
Don't give a false impression. I shimmed up my cams with beer can shims. If you're going to quote me PLS get it right. :woohoo:
  • chconger
  • chconger's Avatar
30 Apr 2015 17:46
#670182
bluezbike wrote: Did not realize it might be a problem, thank you......what do you do to demagnetize your tools?
You probably recognize it; sold an most HW stores. $5 thing for the tool box.
Cheers
Chris
1977 KZ 1000-A
