1st Post, 1st KZ, 1st problem... (starter clutch)
- KZB2 650
Re: 1st Post, 1st KZ, 1st problem... (starter clutch)
17 Mar 2015 07:46
Z1 said no longer available..
Lawn mower Pros no.
Ron Ayers no.
Partszilla no.
World of Power Sports no.
Bike Bandit no.
Chicaogo cycle no.
2 wheel pros no.E replacement parts no.
Kawasaki parts ware house no.
Gear head no.
Fun parts bike center no.
Speed supply .com no.
Metric parts outlet no. And more than a few more that I stopped putting on the list. (at least 10).
Please forget the oil idea.......... our problem is more than that! Mine slipped for the first time and for 7 or 8 times in a row with Mobil 4T synthetic and stopped for 15 starts in a row when I switched to 10/40 Valvoline motorcycle oil BUT on the first cooler day 60s the extra load got it slipping again so mine is right on the edge and was only temporary.
Lawn mower Pros no.
Ron Ayers no.
Partszilla no.
Bike Bandit no.
Chicaogo cycle no.
Gear head no.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Randombeat
- 0 to 100 real quick...
17 Mar 2015 07:49KZB2 650 wrote: Z1 said no longer available..
Lawn mower Pros no.
Ron Ayers no.
Partszilla no.
Bike Bandit no.
Chicaogo cycle no.
Gear head no.
which part no: are you searching for? ive found several places to buy the parts ED listed above. but thats online, and i havent actually placed the order or called to verify they have them.... but the one way assembly 13193-1062 is showing stilll current part that supreceded the original clutch assembly...
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- KZB2 650
17 Mar 2015 09:46
12046-1032 and 13193-1062 ............ many show it available till your ready to order....... In June when I found out I had the problem I was told they were available and could a got one on ebay new but like a dummy I waited till late fall when things slow down for me and lost out.
Also I agree SWest ........ have you ever seen the springs ....... they actually look just like the springs out of a ball point pen....not second guessing the engineer's at Kawasaki but dang.
1978 KZ650 b-2
17 Mar 2015 09:57
Yes they are very flimsy. They need to be so they won't wear out the other parts. All they do is move the rollers to the point they will jam. You might want to look at the ramps to see of there is any deformation that would keep them from moving far enough to work.
17 Mar 2015 10:00 - 17 Mar 2015 10:02
Did they say that both 12046-1032 and 13193-1062 were no longer available?
Last edit: 17 Mar 2015 10:02 by 650ed.
- KZB2 650
17 Mar 2015 10:39
Yes.
1978 KZ650 b-2
17 Mar 2015 11:51
I called
www.partzilla.com
(877.473.4595). They claim 13193-1062 is still available from Kawasaki but say 12046-1032 is not. It might be worth checking on that first one with them to ask them to order it. The second part can be found in new old stock at other parts houses, such as
www.z-power.co.uk
, even though Kawasaki no longer supplies it. Ed
The following user(s) said Thank You: KZB2 650
- DoctoRot
17 Mar 2015 14:10
It will only be a matter of time till a third party starts making replacements for the sprocket. Kawasaki used it until 1993 on the zephyrs. so many bikes out there have this problem or will have this problem i imagine demand will be get to a point where someone with a cnc will start cranking em out.
- KZB2 650
18 Mar 2015 06:37650ed wrote: I called www.partzilla.com (877.473.4595). They claim 13193-1062 is still available from Kawasaki but say 12046-1032 is not. It might be worth checking on that first one with them to ask them to order it. The second part can be found in new old stock at other parts houses, such as www.z-power.co.uk , even though Kawasaki no longer supplies it. Ed
I can't believe I didn't ask you before. I did check with a few in the UK but must not a here. Partzilla told me no I think in Oct and when I ordered the rollers and other parts in Jan I didn't re ask since they were still showing oppsolete and not available still on their sight. I owe you thanks again.
1978 KZ650 b-2
- Tyrell Corp
18 Mar 2015 10:57
I've read here that modern non bike specific oils can cause problems here, although that idea was disputed earlier - i'm really not sure...just an idea, i have this problem myself.
The oil thread smilie
as it is a contoversial subject and tends to get loads of opinions.
Oil is quite sticky, so I think several hundred miles might be needed to remove any anti slip coating 'contaminant', before comparing the problem with different oils.
- Randombeat
19 Mar 2015 21:36
sooo.... ordered the following parts from cheapcycleparts.com :
Product Unit Price Qty Total
SPROCKET,STARTER,58T
Item #12046-1032
CLUTCH-ASSY-ONEWAY
Options: Old Sku: 13193-1012
Item #13193-1062
SPACER,25X36X3.2
SPACER,25X36X3.2
Item #92026-1025
BEARING-NEEDLE,K253017
Item #92046-056
assuming i get them all, (hoping so), do i need anything else, other then an oil pan gasket, oil filter, and oil?
Item #12046-1032
CLUTCH-ASSY-ONEWAY
Item #13193-1062
SPACER,25X36X3.2
SPACER,25X36X3.2
Item #92026-1025
Item #92046-056
- Randombeat
19 Mar 2015 22:23
do i need a clutch basket tool?
