Startup After Top-End Rebuild.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Startup After Top-End Rebuild.
05 Jul 2015 18:00
#679560
You put more stress on your machine in a minute than most of us do in a year. :woohoo:
Been following your build. Good work. B)
  • zukdave
  • zukdave's Avatar
05 Jul 2015 18:12
#679563
Hey it's not stressed the rev. limiters set at 10,500 :woohoo: :woohoo:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
05 Jul 2015 19:18
#679571
zukdave wrote: Hey it's not stressed the rev. limiters set at 10,500 :woohoo: :woohoo:
Well, I mixed all the suggestions together and stirred the pot about 2000 miles ago now...
The only possibly-adverse thing I've noticed are four nicely blued pipes coming out of the engine, though it does run cool while flying like a bat out of hell! :woohoo:
1982 KZ1100-A2/1170 sleeper 😀
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jul 2015 21:04
#679579
Mine wants to go that high but I shift at 9/9.5 when I try to make a light. :evil: Then I'm listening for funny noises. It happens quick. :whistle:
Yeah I do pretty much the same thing. It's not WOT all the time. B)
  • Tyrell Corp
  • Tyrell Corp's Avatar
06 Jul 2015 06:57
#679625
Odd that one of the most used inventions in the world; the piston internal combustion engine that is now 150 years old and we have made billions of them, why such controversy and difference of opinions over such an obvious and vital question? There must be thousands of man- years of accumulated knowledge from motor manufacturer's lab tests done already.
Perhaps we should avoid oil and break in threads and find it easier to agree on sex, politics and religion...or Harleys even :laugh:
  • Nessism
  • Nessism's Avatar
06 Jul 2015 07:39
#679633
Tyrell Corp wrote: Odd that one of the most used inventions in the world; the piston internal combustion engine that is now 150 years old and we have made billions of them, why such controversy and difference of opinions over such an obvious and vital question? There must be thousands of man- years of accumulated knowledge from motor manufacturer's lab tests done already.
I worked for a major Japanese OEM auto company for 21 years and I can assure you, the engines are NOT babied when the factory runs them early in their life. The engine is first run on a dyno where copious amounts of throttle are applied, then the first start up for the car includes a roller run test where again, heavy throttle is used.
I'm of the belief that an easy break-in is not beneficial for parts like the rings, but on a fresh bore they typically seal up fine regardless. On a used cylinder, with some bore wear mixed in, and where the bottom end is already run-in, it makes sense to use the "firm" break-in methodology in my view. Of course someone else will always disagree so there you have it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Jul 2015 07:42
#679634
The idea is to break it in for all riding conditions. I wouldn't expect a Hog to REV out to 10.5 without blowing up as I wouldn't expect my Z1 to putt along at 1200 RPM. Different worlds.
