KZ Turbo Usage History
- Jeff.Saunders
Re: KZ Turbo Usage History
19 Aug 2013 17:16
Les, what is your cam timing? Mine is set at 110/114 using the stock cams.
BTW, my gearing is 15/33 with only a 2" over swing arm - I suspect you are running a little taller gearing - and a much longer swing arm.
www.z1enterprises.com
Z1 Ent on Facebook,
- les holt
19 Aug 2013 19:27 - 19 Aug 2013 19:28
Wow, tall timing! Most don't go there.
111/114
Gearing, 18/38 and 4" over and I'm a little lower on ride height. Close on gearing, I'm a little taller there. Big end charge is crazy!
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
Last edit: 19 Aug 2013 19:28 by les holt.
19 Aug 2013 20:01
Usually run 16 x 33 ratio. currently 15 x 33
Hey Les Didn't ATP make a street kit with the T 25 turbo ? And the race kit was a 40
Cant wait till we get a chance to go riding :evil: :evil: :evil: :evil:
- les holt
19 Aug 2013 20:34 - 19 Aug 2013 20:59
We had better find entertainment for the lady's for a couple hours! Mine likes antiques! FYI, we both have expensive taste so it might be an expensive weekend! LMAO
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
Last edit: 19 Aug 2013 20:59 by les holt.
- NakedFun
19 Aug 2013 20:37
Yes I was a race application engineer for North America. I know turbos and the engine combinations they are attached to. I have done a fair amount of low bench work, but nothing like Larry I am sure. The whole reason I have started this post is because I was looking to narrow the range down so I can focus on gathering maps so I can do my modeling on it. I know Holset data like the back of my hand, but there is no clean comparison or compatibility matrix from Holset to Garret or Borg Warner frame sizes...
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- crh
- Banned
19 Aug 2013 22:11les holt wrote: Wow, tall timing! Most don't go there.111/114
Les
Is that 530 or 630?
- les holt
19 Aug 2013 22:17
530 dRZ2 pure drag race chain. Already wore out and will be replacing when the new chain gets here
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- crh
- Banned
19 Aug 2013 22:39les holt wrote: 530 dRZ2 pure drag race chain. Already wore out and will be replacing when the new chain gets here
Les
Thanks Les. Don't happen to know the diameter of the rear tire do you?
Cory,
Those are some credentials you've got
- Powerstroke_fan
19 Aug 2013 22:41
do anyone use sidewinder chains? Iam running a rear sidewinder sprocket.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
20 Aug 2013 01:24This is why a Busa can make twice the power at the same boost.les holt wrote: My theory is, boost is a measurement of restriction, less restriction and the same amount of boost means way more airflow, more airflow, more horsepower. All that without the added heat involved it would take to make it with restrictions and adding the necessary boost to achieve the same amount of power.
Les
That and combustion efficiency reducing the amount of retard needed to live.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- les holt
20 Aug 2013 07:22 - 20 Aug 2013 07:26gearheadmm wrote:This is why a Busa can make twice the power at the same boost.les holt wrote: My theory is, boost is a measurement of restriction, less restriction and the same amount of boost means way more airflow, more airflow, more horsepower. All that without the added heat involved it would take to make it with restrictions and adding the necessary boost to achieve the same amount of power.
Les
Exactly!
As for rear tire dia., Don't know but sure it's a little shorter than the stock kz 18" setup. 180/55-17 Michelin Power One 2ct. it's taller than the dunlaps and shinkos of the same size by but a bit.
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
Last edit: 20 Aug 2013 07:26 by les holt.
- turboking
20 Aug 2013 09:33Street Fighter LTD wrote: Usually run 16 x 33 ratio. currently 15 x 33
:blink: I sold and installed plenty of ATP kits in the 70's..... :evil: honda kits were b series rayjay was for less than 900 cc...... :dry: F series rayjay were 900 cc and up.......
both street and race kits for z's were F flow ..... F 40 single feed bearing for the standard street kit and F 40 dual feed bearing was for the race kits ( more oil feed holes in the bearing sleeve).....i know on the kz 550 atp kit they used an ishi turbo ....really tiny :lol:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
