KZ Turbo Usage History
- undiablo
Re: KZ Turbo Usage History
16 Aug 2013 19:25
Do you guys know if it is possible to run a turbo setup on a KZ750 with keihin CV34 carbs? I still don't want to go fuel injection. I presume I will have to rejet carbs right?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- NakedFun
16 Aug 2013 23:48
CV carbs will need to have a pressurized plenum in order to work properly. It would take some work, but the ZRX1100/1200 guys with the Keihin CVK36's do it all the time. Even with mechanical slides the pressure plenum is required for blow through due fuel bowl venting.
Stroker Fan,
What did you buy....?
Cory
Stroker Fan,
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
The following user(s) said Thank You: undiablo
- Jeff.Saunders
17 Aug 2013 09:42
Here's my setup. The turbo was initially installed on the bike by a previous owner around 1980. Since then the engine has been apart and refreshed / improved.
- RayJay 370 turbo with ATP manifold and spider pipe.
- 1200cc Wiseco 8:1 turbo pistons.
- Welded crank.
- Stock cams with slotted cam sprockets.
- 31mm exhaust valves (stock is 30mm). 36mm (stock) intake valves.
- Heavy Duty main bearing and cylinder studs.
- The oil pump was modified to move the pickup to the bottom of the deep sump oil pan, and to optimize the flow (the pump case halves were lapped to improve the performance).
- MRE lock-up clutch with OEM-Style clutch plates and springs - this was after battling very heavy clutch springs and an extra disk clutch for a couple of years - it was killing my wrist and giving harsh control pulling away.
- Liska idler sprockets and tensioner assembly with a Tsubaki HD cam chain.
- The cylinder head gasket surface is ringed with piano wire.
- Dyna 2000 ignition hooked up to a boost sensor triggering the retard settings.
- HSR 42 carb fed by a 3-4 psi fuel pump
- Extra breather ports on the valve cover.
- Air/fuel sensor on the spider pipe and a readout on the handlebars.
- NakedFun
17 Aug 2013 10:49
Very Nice Jeff. I know the RayJays were popular back in the day, but when RayJay got bought out, the name and alot of info like comp maps are hard to find. Who O'Ring'd you head?
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Jeff.Saunders
17 Aug 2013 13:28 - 17 Aug 2013 15:15
The wire ring was already done when I bought the bike.
I don't have any performance info on the RayJay - but I do have an original service document.
Here's a PDF copy. RayJay Manual
Last edit: 17 Aug 2013 15:15 by Jeff.Saunders.
17 Aug 2013 13:56
Joe at Pitstop can do the wire ring. Mine is in the block, When he fitted my MTC pistons he put new wire in the block for me.
- wireman
17 Aug 2013 14:04Somebody else realized the advantages of spending time/money on exhuast side of a cylinder head for a turbo motor.Jeff.Saunders wrote: Here's my setup. The turbo was initially installed on the bike by a previous owner around 1980. Since then the engine has been apart and refreshed / improved.
- Welded crank.
When I suggested this many times on here in the past I was told I didnt know what I was talking about ,It seems somebody else has had good luck fooling a smaller cylinder head into thinking its more efficient with oversize exhuast valves/stock size intakes since the exhuast side is what gets that turbo spooling.
That turbo doesnt care so much what the intake valve size is,its force feeding it.
- NakedFun
17 Aug 2013 14:11
That is true to a point. Too much turbo or not enough intake port volume can lead to excessive intake tract pressure which can work against the turbo causing a surge. You are correct on the exhaust as most N/A engine application are most efficient at a exhaust valve to intake valve size percentage of 70-76% typically. On a turbo charged application where the thermal energy cause exhaust gas expansion that is mostly regulated by the swallowing capacity of the turbine housing/wheel combination can find gains of an additional 5-10% of Ex/In size increase with corresponding port work.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Powerstroke_fan
17 Aug 2013 15:29NakedFun wrote: CV carbs will need to have a pressurized plenum in order to work properly. It would take some work, but the ZRX1100/1200 guys with the Keihin CVK36's do it all the time. Even with mechanical slides the pressure plenum is required for blow through due fuel bowl venting.
Stroker Fan,
Cory
Nothing yet, but iam really temped if i come across the right deal.
1977 KZ 1000 work in progress
- Jeff.Saunders
17 Aug 2013 19:30 - 17 Aug 2013 19:32wireman wrote: Somebody else realized the advantages of spending time/money on exhaust side of a cylinder head for a turbo motor.
When I suggested this many times on here in the past I was told I didn't know what I was talking about ,It seems somebody else has had good luck fooling a smaller cylinder head into thinking its more efficient with oversize exhaust valves/stock size intakes since the exhaust side is what gets that turbo spooling.
That turbo doesn't care so much what the intake valve size is its force feeding it.
The person that helped me understand turbochargers was Frank Davis (Fast Frank) of Powerhouse Motorcycles on Long Island. I stuck with his recommendations. He has a turbocharged KZ1000 with NOS that's run 190+ mph in the flying mile - all without a fairing. His business specializes in turbo bikes.
Last edit: 17 Aug 2013 19:32 by Jeff.Saunders. Reason: add
- crh
- Banned
17 Aug 2013 20:36 - 17 Aug 2013 21:09wireman wrote:Somebody else realized the advantages of spending time/money on exhuast side of a cylinder head for a turbo motor.Jeff.Saunders wrote: Here's my setup. The turbo was initially installed on the bike by a previous owner around 1980. Since then the engine has been apart and refreshed / improved.
- Welded crank.
kzrider.com/forum/9-chit-chat/588431-wireman-read-this
That stuff is old school thinking. There's more to making power than spooling up the turbo. But, then again, you have to know how to grind on the Inside of the head rather than the fins :lol:
Zmax Turbo Head
Attachment l3.jpg not found
Last edit: 17 Aug 2013 21:09 by crh.
- wireman
17 Aug 2013 22:48
Thats cosmetic stuff there sunshine,that head was already ported. :whistle:
Some people actually pay attention to details.
Yeah thats old school thinking on the turbo head porting,but heres a news flash it actually works really good.
I think the picture of Jeffs friends bike proves that point with what its capable of.
