- Thank you received: 299
What kind of power should I expect to make
- wireman
- wireman
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- wireman
- racer54
- Thank you received: 114
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- gpz1170
- Thank you received: 10
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- LarryC
gpz1170 wrote: I've known of a couple of guys to use a GPZ block on a KZ bottom end, with a KZ crank ( you need to use a Suzuki flat roller cam chain ), with the sliders. The purpose was to see what it took to do it and if it was practical. I have a step by step discription of the process and it's several pages. For me way to much trouble not to use a KZ block.
don
See...another approach to it Anything can be made to work with enough determination..
Larry C.
- Rowdymk2
- lushbaugh
- everybodys a pro......
- Thank you received: 35
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- turboking
- Thank you received: 106
see what the 9x does for guide life..... guides will have accelerated guide wear front to back from the big lift any brand :evil: big lift cams are guide killers, and then you wonder why your super duper head didn't hold it's valve job.... not street-able IMO :S . if your looking for the choppy big cam lope :pinch: pull some choke on it to get the desired cool effect :dry: I'm not bashing, just my .02 :silly: :side:
:whistle: :whistle: eerrrrr i'm rambling again...
9X in .500 280 deg. 28/72 .157 112 .004
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
