- Thank you received: 83
What kind of power should I expect to make
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- les holt
- Thank you received: 288
Les
- wireman
- Thank you received: 299
- Rowdymk2
- Rowdymk2
- kzz1king
- Thank you received: 52
Isn't it some Honda starter that is used to crank the bigger motors?Rowdymk2 wrote: I was thinking a kz 13 starter would have enough ass to turn it over and if not the 9 has a kicker also
Wayne
Home built KZ1000 turbo setup
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Rowdymk2
- Rowdymk2
- wireman
Bolts in place of stocker,Ive heard gpz1100 starter is stronger alsoRowdymk2 wrote: Does that starter bolt in or is that the external you see at the track
- les holt
Les
- sflaz1
Rowdymk2 wrote: I am either gonna use a j model head or the 900 head ported not really sure what size valves to get or or what cam would even be the best I have my eye on the Andrews 2x but I am not afraid to modify the the head and go bigger . I want this build to make a radical street machine that will cruise around town and have enough power to run some of the newer bikes out . This bike is not my main transportation . 125 is at the wheel I hope . I was kind of shooting for around 150 . I stretched a swingarm 6 over witch will be going on tomorrow if time is on my side before I go to work. This is the first time I have ever built a bike engine other than oem rebuild so any pointers would great . And please leave out the buy a zx10 and 13.5:1 is not gonna be good on the street commentary . Because I know that with the right cam and carb combo it will be fine . This is not a touring rig thanks in advance
If you use a J model head you will have to use J model pistons or the compression will be considerably lower due to the larger tub size of the combustion chambers. APE told me that unless your running a big block there is not much to gain with the J model head.
Bought my 1973 Z1 in late 1978. Turbo charged 1982.
