What kind of power should I expect to make
  • Rowdymk2
  • Rowdymk2's Avatar Topic Author
18 Feb 2013 03:16
#572957
I just bought a wiseco 1197 13.5:1. Kit for my kz I am planning to run 33 smoothbores and Andrews 2x or 3x cams what do you think a ball park hp and torque estimate would be ? Thanks in advance for your insight
  • wireman
  • wireman's Avatar
Re: What kind of power should I expect to make
18 Feb 2013 03:27
#572958
What are you doing to the cylinder head? B)
The following user(s) said Thank You: turboking
  • baldy110
  • baldy110's Avatar
18 Feb 2013 14:17
#573020
13.5 to 1 compression, wow is this on a street engine or drag bike?
  • wireman
  • wireman's Avatar
18 Feb 2013 15:44
#573029
I ran 13.5:1 1197 pistons in my 74 z1,big cam with a lot of overlap knock a lot of the actual cranking/cylinder pressure off.
Without knowing whats being done to the head theres know way to estimate horsepower.
It could make 105hp or it could make 125hp B)
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
18 Feb 2013 16:46
#573040
wireman wrote: It could make 105hp or it could make 125hp B)
115hp would be a good estimate in that case :laugh:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • Rowdymk2
19 Feb 2013 03:53
#573134
I am either gonna use a j model head or the 900 head ported not really sure what size valves to get or or what cam would even be the best I have my eye on the Andrews 2x but I am not afraid to modify the the head and go bigger . I want this build to make a radical street machine that will cruise around town and have enough power to run some of the newer bikes out . This bike is not my main transportation . 125 is at the wheel I hope . I was kind of shooting for around 150 . I stretched a swingarm 6 over witch will be going on tomorrow if time is on my side before I go to work. This is the first time I have ever built a bike engine other than oem rebuild so any pointers would great . And please leave out the buy a zx10 and 13.5:1 is not gonna be good on the street commentary . Because I know that with the right cam and carb combo it will be fine . This is not a touring rig thanks in advance
  • wireman
  • wireman's Avatar
19 Feb 2013 04:10
#573135
With a decent head 125hp at rear wheel wont be a problem,you do realize youll have to start with a bare set of engine cases and build this motor from ground up right?
Don't worry,I hate zx10s! :woohoo:
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
19 Feb 2013 08:54 - 19 Feb 2013 09:30
#573143
Its deffitenly a lot of work and its not cheap. Youll need welded crank, back cut trans, cams, carbs, head work, and on and on. It adds up really fast. And if you a j head you have to buy a idler tower to make it work. You gotta machine the head to make the tower fit.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 19 Feb 2013 09:30 by Powerstroke_fan.
  • Rowdymk2
19 Feb 2013 12:33
#573166
I am aware of all the work that goes with this project and can done most machining my self it's kind of my line of work . I am a industrial maintenance machinist . But the thing I would like to know is what is a good cam set I know that the higher lift cam will make it run much cooler . Another thing is what size jets would I need to run on pump gas 93 octaine . And in advance I live in indiana where there is now admission testing . The is and still will be Vance and Hines with no baffle . I am not worried about the money I am piecing this motor together mostly from eBay and a couple of sources I have here around home . If you have any tips as to what I can do to make good power my ears are open the motor I am building is a donor and I said I will be doing most all off the work so let's talk about valves jetting dual plugs timing lock up clutches what is the best ?
  • steell
  • steell's Avatar
19 Feb 2013 13:37
#573177
What part of Indiana has emission testing? Northwest Indiana?
  • wireman
  • wireman's Avatar
19 Feb 2013 17:56
#573200
If theyre doing emmisions testing there Id say youre screwed unless you can license it someplace else.
Do they do a visual inspection also or just mechanical testing?
  • floivanus
  • floivanus's Avatar
19 Feb 2013 18:17
#573205
Lake and porter county, right where the mills are.
Past; 78 kz1000, 83 kz550
Andrew
