Bike wont start after rebuild, need help please
- strobel5
06 Oct 2012 18:13 #552774
by strobel5
1978 kz650d(SR)
Replied by strobel5 on topic Bike wont start after rebuild, need help please
So I got it running, barely. It runs but there is a spitting noise coming from the carbs like a backfire almost at random intervals. Also whenever I go to give it some throttle it bogs down. What does this mean?
1978 kz650d(SR)
- bountyhunter
- Thank you received: 337
06 Oct 2012 18:32 - 06 Oct 2012 18:33 #552775
by bountyhunter
Agree on a comprehensive top down clean and tune for the fuel system. Flush tank, clean petcock, install new filters, clean and tune carbs.
Replied by bountyhunter on topic Bike wont start after rebuild, need help please
Could be timing too advanced, could also be carb (fuel level) problems or similar.strobel5 wrote: So I got it running, barely. It runs but there is a spitting noise coming from the carbs like a backfire almost at random intervals. Also whenever I go to give it some throttle it bogs down. What does this mean?
Last edit: 06 Oct 2012 18:33 by bountyhunter.
- Thank you received: 2098
06 Oct 2012 18:39 #552779
by Patton
Replied by Patton on topic Bike wont start after rebuild, need help please
As the advancer's F mark for 1/4 aligns with the case mark, the contacts on the left-hand points should just begin to open.
Opening of the points is the event that causes the ignition coil to fire.
Forget about the T mark when adjusting the ignition timing.
And remember to set the correct gap before adjusting the timing.
- strobel5
07 Oct 2012 11:23 #552901
by strobel5
1978 kz650d(SR)
Hmm I might of used the T mark when adjusting the timing, I will go back and look. If thats not it I will take the carbs off again. Thanks everyone for the help!
1978 kz650d(SR)
- strobel5
13 Oct 2012 14:55 - 13 Oct 2012 15:01 #553651
by strobel5
1978 kz650d(SR)
So this is embarrassing but I found the problem to the hard starts and high idle, my throttle cable was too tight. Fixed that and now its running great. Thanks everyone, this site has made it possible for me to rebuild a engine for the first time.
1978 kz650d(SR)
Last edit: 13 Oct 2012 15:01 by strobel5.
