- Thank you received: 337
Bike wont start after rebuild, need help please
- bountyhunter
- OKC_Kent
- Thank you received: 20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- Thank you received: 2098
If timing advancer was removed and replaced, would assure that the rotor is positioned correctly, and not 180° off.
( I see where bountyhunter had already suggested this. )
- strobel5
1978 kz650d(SR)
- strobel5
1978 kz650d(SR)
- strobel5
1978 kz650d(SR)
strobel5 wrote: Also on that diagram, does it matter which terminals the wires go to. like green on the outside red/yellow inside?
It doesn't matter, because the coil primary winding terminals are non-polar.
The concern in the case at hand is not so much about the existence of good spark as it is about the timing of the good spark.
If the plug wires from the coils are attached to the wrong plugs, or if the signal wires are reversed by being attached to the wrong coil, or if the advancer rotor is 180° off, the timing of the good spark will be incorrect.
- Garn
- Thank you received: 13
The down side to this, is you often then soot up the plugs quickly!
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- sflaz1
Bought my 1973 Z1 in late 1978. Turbo charged 1982.
- strobel5
2/3 TDC
Attachment IMG_1226.JPG not found
1/4 TDC
Attachment IMG_1227.JPG not found
1978 kz650d(SR)
- strobel5
1978 kz650d(SR)
- Motor Head
- Thank you received: 391
but good to here it will try, probably need to pull the carbs and clean them. Clean the fuel tank and petcock. Maybe put on new line, and a in-line filter for a gravity feed system, not for a pump.
