Bike wont start after rebuild, need help please
- strobel5
04 Oct 2012 22:51 #552495
by strobel5
1978 kz650d(SR)
Bike wont start after rebuild, need help please was created by strobel5
So I finally got everything back together on my project, I went to start it and there is nothing. It is turning over, has spark, and is getting fuel to the carbs. I know the compression is good too. When I go to kick start it there doesnt seem to be much backpressure and it is dead quite, like just turning over thats it. I know its hard to give advice on an issue like this but please any tips or ideas are welcomed. Is there a way to see if the carbs are working properly?
1978 kz650d(SR)
- Motor Head
- Thank you received: 391
04 Oct 2012 22:54 #552497
by Motor Head
Replied by Motor Head on topic Bike wont start after rebuild, need help please
Check your compression with a gauge. Sounds like you say it is not feeling right kicking it.
- strobel5
04 Oct 2012 23:15 #552501
by strobel5
1978 kz650d(SR)
Replied by strobel5 on topic Bike wont start after rebuild, need help please
Thank you for your response. I did a compression check recently and I got 1:155 2:150 3:125 4:175, these numbers are after a top end rebuild. I know the compression is off but shouldnt I at least get some kind of running with that compression? As far as the kick starting I am only assuming since I actually never kick started it prior to rebuilding it.
1978 kz650d(SR)
- Motor Head
04 Oct 2012 23:19 #552503
by Motor Head
Yes those are plenty high enough. the lower one could be an issue though.
So when you kick it, it doesn't feel right?
Do the plugs get wet with fuel?
Any fuel actually in the bowls, open a drain screw and see fuel flow out?
- strobel5
04 Oct 2012 23:22 #552504
by strobel5
1978 kz650d(SR)
When I kick it, it almost seems too easy, but its smooth and everything. Havent check plugs but I did check the bowls and they have fuel. Timing maybe?
1978 kz650d(SR)
- Motor Head
04 Oct 2012 23:25 #552505
by Motor Head
Any Pop or Back fire? Sign of life? Got the plug wires on right, and the correct pick-up/ points for each coil? They usually Pop and back fire if it is wrong.
- strobel5
04 Oct 2012 23:33 #552509
by strobel5
1978 kz650d(SR)
No sound of life at all, thats what sucks. I checked the leads and everything/
1978 kz650d(SR)
- Motor Head
04 Oct 2012 23:45 #552512
by Motor Head
So check the plugs and see if they are wet. If not try a small amount of fuel down the plug holes and try again. I like this better than starting fluid/ ether.
- strobel5
04 Oct 2012 23:51 #552518
by strobel5
1978 kz650d(SR)
Ok thanks for the help, I will try tomorrow and see
1978 kz650d(SR)
- Motor Head
04 Oct 2012 23:56 #552520
by Motor Head
So it ran before the rebuild, but how long ago was that? And has it been sitting with gas/ Deathanol in the tank and carbs? You small fuel drillings/ jets might be plugged with corn syrup. The starter/ enrichment jet might be plugged. Did you do any carb work?
- 4TheKZ1000
- Visitor
05 Oct 2012 00:09 #552529
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Bike wont start after rebuild, need help please
Make sure your doing this outside if possible or inside with a fire extinguisher at hand.
- strobel5
05 Oct 2012 00:12 #552533
by strobel5
1978 kz650d(SR)
ha ok good point.
1978 kz650d(SR)
