- Thank you received: 1557
650 bucket in a 1000?
- zed1015
05 Oct 2012 12:22 #552601
by zed1015
Replied by zed1015 on topic 650 bucket in a 1000?
Very hard to pass judgement by the pic and fitting 650 buckets etc is no big deal and a common mod when using hairy cams as long as they used the matching retainers etc (although you would usually do the whole lot :lol: )
Here's a couple of thoughts on possible causes/bodges.
1. It's a shim over bucket that has had the shim recess filled with a filler material and ground back - weld etc (rather that buy a shim) to get it to run for a quick sale.
2. 650/J style bucket that has serious wear through the hardening.
The cam lobe does not run right up to the edge of the bucket and the buckets rotate during use so this would result an un worn portion round the edge that could mimic a shim over bucket appearance from a distance.
- 4TheKZ1000
- Visitor
05 Oct 2012 13:05 - 05 Oct 2012 15:17 #552605
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 650 bucket in a 1000?
I really think its a Shim On Top that spit a shim and then hopped around but didnt leave its bore. It was chewed on by the worm gear for the tack or the lobe hammered on it. Look at the closest teeth / gears of the tach drive to the bucket....they are shinny while the others are black??????? Rem that the top of the bucket had extra distance to travel due to shim missing...what like a 2 to 3 mm travel....its pretty clear to me with all the maring and markings on the outer collar it had some help getting there.
Last edit: 05 Oct 2012 15:17 by 4TheKZ1000.
- Thank you received: 2064
05 Oct 2012 13:22 #552613
by Street Fighter LTD
Replied by Street Fighter LTD on topic 650 bucket in a 1000?
My .02
Bottom Line, Remove the cams as the bucket is toast regardless of what it is..
Pull out the bucket and the guessing is over. The motor is unservicesable as is so nothing to lose by digging into it so you will know what the damage is and start the healing process. I would also pull the oil pan and cleanout the debris and check the oil pump. Time for a rebuild :S :S :S
Wishing you good luck and minimal damage to the bike and your wallet.
- Thank you received: 797
05 Oct 2012 16:41 - 05 Oct 2012 16:43 #552640
by 531blackbanshee
Replied by 531blackbanshee on topic 650 bucket in a 1000?
i have spit a shim out.
they go out the side of the head and valve cover,a long ways,out beside the road,across the railroad tracks.
hope your knee isn't in front of it when it goes.
that does not look like a shim on top that has lost a shim.
that looks like a shim on bottom with wear marks.
how does the clearance measure?
thats my .02 ymmv,
thats my .02 ymmv,
Last edit: 05 Oct 2012 16:43 by 531blackbanshee.
- built408
05 Oct 2012 17:34 #552644
by built408
1978 KZ1000 A2A with MKII body you know you like it
Replied by built408 on topic 650 bucket in a 1000?
Well I figured it out it's wait drumroll....... it's a 650 shim under.
- 4TheKZ1000
- Visitor
05 Oct 2012 17:35 #552645
by 4TheKZ1000
:dry:
built408 wrote: Well I figured it out it's wait drumroll....... it's a 650 shim under.
:dry:
- Old Man Rock
- Thank you received: 225
05 Oct 2012 21:25 #552681
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 650 bucket in a 1000?
"Remove the cams as the bucket is toast regardless of what it is.."... We have a winner!
New replacement bucket, shit dime a dozen, ebay or new whatever.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- zukdave
- Thank you received: 229
05 Oct 2012 21:37 - 05 Oct 2012 21:45 #552683
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic 650 bucket in a 1000?
Hey the cool part you know those hotter cam's ???
Now you got a reason to buy some.
If you put that cam on a new bucket the
bucket will be junk shortly after.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 05 Oct 2012 21:45 by zukdave.
- Powerstroke_fan
- Thank you received: 83
05 Oct 2012 22:56 #552695
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic 650 bucket in a 1000?
Still dont make since why someone would have only one shim under bucket. Its too much work to change the retainers for just one bucket. I would make sure that it has the proper retainer. And make sure you get the proper bucket.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
