650 bucket in a 1000?
  • built408
  • built408's Avatar Topic Author
04 Oct 2012 19:50 - 04 Oct 2012 20:03
#552468
Attachment kz3.jpg not found
Is it possible that someone put a 650 bucket in my 1000. It appers to only be one any advice on how or should I fix this? This doesn't make any sense because it is only one exaust valve.
1978 KZ1000 A2A with MKII body you know you like it
Last edit: 04 Oct 2012 20:03 by built408. Reason: spelling
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 650 bucket in a 1000?
04 Oct 2012 19:57 - 04 Oct 2012 20:12
#552470
I showed this picture to WIREMAN.....push link below to hear his comment.....
www.shockwave-sound.com/sound-effects/sc...ds/female_scream.wav
Thats some f-ed-up chit...the bucket issue is also? :sick: :sick: :ohmy: :ohmy: :lol: :lol: :woohoo: :woohoo:
Last edit: 04 Oct 2012 20:12 by 4TheKZ1000.
  • 4TheKZ1000
04 Oct 2012 20:20
#552474
so you have 7 normal shim on top buckets...but this one exhaust bucket (pictures) is damaged or might have been replaced with a 650 shim under bucket?
It looks like a damaged shim on top bucket to me......Forum please chime in!!
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
04 Oct 2012 20:38
#552477
It does look kinda like it is a sim on top bucket. but it looks jacked up.
1977 KZ 1000 work in progress
  • built408
04 Oct 2012 21:11
#552481
Na I did some poking around and it's definitely one piece and lookin at some 650 buckets it kinda looks like a 650 bucket I hope :unsure: . the attached pic looks a lil better my pic quality isen't the best the glare makes surface scratches look a Lot worse than they are I'll try and get a better pic but it's DEFINITELY one piece.
  • 4TheKZ1000
04 Oct 2012 21:31 - 04 Oct 2012 21:31
#552484
the most outer rim on my buckets are perfect with no marks...yours look like a bench grinder hit it...a 650 bucket wouldnt look like this either????that thingamajig got chewed up a spat-out..... :sick: :sick: :sick:
Last edit: 04 Oct 2012 21:31 by 4TheKZ1000.
  • Motor Head
  • Motor Head's Avatar
04 Oct 2012 22:11
#552485
Whats the valve clearance look like?
From the picture, Blurry, it looks like it lost a shim and fubared the rim around the top of the bucket. Cam looks like it has a wear pattern also.
Better pictures would help.
  • 4TheKZ1000
04 Oct 2012 22:21
#552487
Motor Head wrote: Whats the valve clearance look like?
if you spit a shim....where is the shim???? oil pan??? chewed up???
  • Motor Head
04 Oct 2012 22:29
#552489
Could migrate to the pan. I have a head here with a big hole in the front of it, as it spit an exhaust shim. Was on a bike I bought cheap.
  • wireman
  • wireman's Avatar
04 Oct 2012 23:38
#552510
Time to pull the cams out and do an autopsy on it B)
05 Oct 2012 11:38
#552593
KZ1000 has shim on top of the bucket, held in place by a raised rim around the bucket surface.
The cam lobe rides directly against the shim.
KZ650 has shim under bucket, and a smooth rimless surface where the cam lobe rides.
The KZ1000 at hand is supposed to have buckets with the raised rims.
Does the bucket in question have a raised rim or not?
Good Fortune! :)
  • OnkelB
  • OnkelB's Avatar
05 Oct 2012 12:06 - 05 Oct 2012 12:13
#552596
Below is a 650 bucket (left) and a KZ1100 bucket with the shim removed (right).
Quick and easy way to determine what you have: rotate the bucket in the head, if it has a notch in the upper edge (marked red in the pic) it's not a 650 bucket.
Sorry to say, but to me it looks like a shim on top bucket with no shim in it, hope I'm wrong.
Btw, as a sidenote you can't just swap a 650 (or any other shim on bottom type) bucket into a shim on top head, you also need to change the retainer - the retainers in a shim on bottom setup have a recess in them to hold the shim.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 05 Oct 2012 12:13 by OnkelB.
The following user(s) said Thank You: Patton
