- Thank you received: 103
Mystery Engine
- roy-b-boy-b
Now to remove paint. Cylinders and head. I hate that job. Roy
- roy-b-boy-b
- Kidkawie
- I bleed premix
- Thank you received: 245
Patton wrote: If interested --
www.harborfreight.com/6-piece-telescoping-gauge-set-5649.html
You can find a dial bore gauge set for about $50 online.
Roy, I wouldn't want to ride that thing on the street, cam is huge.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- LarryC
Larry C.
- roy-b-boy-b
I removed the notched cam sprockets and there was a some numbers that I hadn't seen before. They were not under the sprockets but on the edege where the sprockets bolt up.
They are stamped. with small and large figures. It is my quess if the circles are o's or 0(numeral)
very small o1 big 70.465B.060
I have googled with no luck but will keep trying.
- 4TheKZ1000
- Visitor
Attachment IMG0450A.jpg not found
Attachment IMG0448A.jpg not found
Attachment IMG0447A.jpg not found
Attachment IMG0446A.jpg not found
Attachment IMG0445A.jpg not found
- roy-b-boy-b
Where are the Web marks on yours at? Thanks. Roy
- LarryC
4TheKZ1000 wrote: Hey Roy, does this help.
Web grinds the identifying info on the ends of the cams.
Larry C.
- LarryC
roy-b-boy-b wrote: The i.d. of these cams came up on another site so I got them out again and looked for more markings.
Roy,
I'll speculate that if you measure your cams you may well find they have .465" lift with a 1.060 base circle. Measure them and see. The 70 might possibly refer to 270 degrees of duration. If it does, it most likely specs out for less than .050" checking lift for that.
The would be a great cam in a big cc motor, not worth a dam in a moderate compression 1075 for anything but racing.
Larry C.
- roy-b-boy-b
- kopcicle
- Thank you received: 4
My best guess at the pistons is MTC 13.5:1 75mm , 1166cc
I'd be guessing at the cams .
~kop
stay in touch I might have use for a piston or two
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
- APE Jay
- Banned
- Thank you received: 58
