- Thank you received: 103
Mystery Engine
- roy-b-boy-b
I will look at them again more closely.
The guy that owned the bike when it was raced was a kawasaki mechanic for years. Both mechanics at the shop usally had their engines built by sonny that is no longer with us.
I really didn't want to tear the engine down but might have to. It has compression out of this world.
The guy I bought it from told me it was a built engine but I didn't pay him no mind as I was wanting other parts off the bike.
Les. I lost the PM. I'll think about it. Roy
- roy-b-boy-b
- APE Jay
- Banned
- Thank you received: 58
- roy-b-boy-b
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- roy-b-boy-b
I couldn't tell if the engine had a cometric gasket on it. How can I tell if the engine is bigger than a 900cc. Can compression tell?
I found a cam cover the has the X's ground off. I don't think they were done by hand! :huh:
I might just install the cams in my 1075 engine. I had to sell my 3X cams last year when I was broke and this will put me back on track. I got $255.00 for the 3X and only paid $175.00 for this bike. So that will put me ahead a little.
I didn't find any more markings.
- LarryC
roy-b-boy-b wrote: Thanks again. This bike has all chrome covers from Browns Plating. Roy
That's got to be worth 6 HP
Larry C.
- LarryC
roy-b-boy-b wrote: I'm going to fire the engine.
Point the lobe straight up and get a photo from the side. The profile view will give a good indication of ballpark duration.
Larry C.
- roy-b-boy-b
- LarryC
Web 118, Cam Motion Z1, Web 109
Attachment cams.jpg not found
Larry C.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
