Mystery Engine
29 Mar 2012 17:52 #512834 by roy-b-boy-b
Mystery Engine was created by roy-b-boy-b
I was working on the A4 today. I tore the top end down because two spark plugs were broke off flush with the head.
The number three piston had water in it so I needed another top end.
I had the 900 LTD so I went and got it thinking I would start it and maybe remove the top end or swap out engines.
I removed the cam cover. It was a pain to get off. I noticed it had two gaskets on it. I set the A4 cover on the engine and it would not fit down by a long shot.
I started looking at the cams and they were not stock. The head had been clearanced and it had shim under bucket.
The cams measured .418 as best as I could measure.
The cams had these markings on them.
Exhaust, Made in USA, EP14,F19
Intake, GWC,EP14
Does anyone know what these cams are?
The bike had been set up as a dirt drag trike.
Notice the blank journal on the intake. Maybe it could be machined as the tach drive for a exhaust cam.
29 Mar 2012 18:03 #512838 by jeffasaki
Replied by jeffasaki on topic Mystery Engine
Andrews?
Always nice to discover hidden treasure
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
29 Mar 2012 18:29 #512851 by roy-b-boy-b
Replied by roy-b-boy-b on topic Mystery Engine
Not Andrews. Andrews cams has Andrews cast in them with a 3X on the end. Thanks for responding. Roy
29 Mar 2012 18:38 #512853 by jeffasaki
Isky?
could be worth some coin
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
29 Mar 2012 18:52 #512858 by roy-b-boy-b
I need coin !!
29 Mar 2012 19:56 #512878 by les holt
Replied by les holt on topic Mystery Engine
My andrews don't have andrews cast in them but they are stamped 3X andrews on the ends. Look for stampings on the ends, most manufactures do that I have seen.
Nice find
Les
29 Mar 2012 19:58 #512879 by roy-b-boy-b
No markings on end. Roy
29 Mar 2012 20:29 - 29 Mar 2012 20:33 #512885 by Powerstroke_fan
Replied by Powerstroke_fan on topic Mystery Engine
not positive but i think i my psp 3x, same as the old andrews has a gwc stamped in the same spot
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 29 Mar 2012 20:33 by Powerstroke_fan.
29 Mar 2012 20:42 #512888 by jeffasaki
could be the ultra rare
Burt Munro specials
Made from kiwi bones and hardened in coral :P
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
29 Mar 2012 20:55 - 29 Mar 2012 20:58 #512892 by ramtough_63
Replied by ramtough_63 on topic Mystery Engine
Attachment bertmonro01.JPG not found
Anybody seen my Cams??
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Last edit: 29 Mar 2012 20:58 by ramtough_63.
29 Mar 2012 21:15 #512894 by taildragger1197
Replied by taildragger1197 on topic Mystery Engine
OMG! Is That Roy?
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
29 Mar 2012 22:01 - 29 Mar 2012 22:03 #512905 by APE Jay
Replied by APE Jay on topic Mystery Engine
roy-b-boy-b wrote: I was working on the A4 today. I tore the top end down because two spark plugs were broke off flush with the head.
Intake, GWC,EP14
Those are just the Engine Power billet numbers. EP14 is their number for the Kawasaki KZ blank. CWC was the name they used before. Those should be cast into the blank, so it will not tell you who bought the blanks and ground the lobes. That is usually done with a steel stamp or vibe pencil
Last edit: 29 Mar 2012 22:03 by APE Jay.
