- Thank you received: 103
Mystery Engine
- roy-b-boy-b
The number three piston had water in it so I needed another top end.
I had the 900 LTD so I went and got it thinking I would start it and maybe remove the top end or swap out engines.
I removed the cam cover. It was a pain to get off. I noticed it had two gaskets on it. I set the A4 cover on the engine and it would not fit down by a long shot.
I started looking at the cams and they were not stock. The head had been clearanced and it had shim under bucket.
The cams measured .418 as best as I could measure.
The cams had these markings on them.
Exhaust, Made in USA, EP14,F19
Intake, GWC,EP14
Does anyone know what these cams are?
The bike had been set up as a dirt drag trike.
Notice the blank journal on the intake. Maybe it could be machined as the tach drive for a exhaust cam.
- jeffasaki
- Thank you received: 44
Always nice to discover hidden treasure
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- roy-b-boy-b
- jeffasaki
could be worth some coin
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- roy-b-boy-b
- les holt
- Thank you received: 288
Nice find
Les
- roy-b-boy-b
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- jeffasaki
Burt Munro specials
Made from kiwi bones and hardened in coral
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- ramtough_63
Attachment bertmonro01.JPG not found
Anybody seen my Cams??
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- taildragger1197
- Thank you received: 17
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
- APE Jay
- Banned
- Thank you received: 58
roy-b-boy-b wrote: I was working on the A4 today. I tore the top end down because two spark plugs were broke off flush with the head.
Intake, GWC,EP14
Those are just the Engine Power billet numbers. EP14 is their number for the Kawasaki KZ blank. CWC was the name they used before. Those should be cast into the blank, so it will not tell you who bought the blanks and ground the lobes. That is usually done with a steel stamp or vibe pencil
