GPZ750/810 racer running....
- larrycavan
Re: GPZ750/810 racer marching on
10 Feb 2011 14:05
CoreyClough wrote:
Great Videos!
I take it that's a mixed class ???
What oil are you planning on using? Redline 20w/50 here, and plan to change the oil and filter after every race weekend.
You shouldn't have to rebuild that bottom end at all, after all you are doing to it. Top end, maybe, but I can't see you doing the bottom.
I am also using a Daytona Oil Temperature Gauge (ShindyPro.com) tapped into the oil pan for oil temperatures, and checking it on a long straight, I'll see 208 degrees F regularily, and that using an oil cooler from a Zephyr ZR550 too. Being Oil Cooled, you gots-ta know.
I modified the low oil level sensor to fit the temp probe:
I was using a Dyna Shift Minder, but now am now use a Raptor Shift Light. Small, 3-wire connection, and easy to adjust at the light:
www.raptorperformance.com/
...as seen in this video set at Infineon last year:
Great Videos!
- kzr750r1
12 Feb 2011 08:05 - 12 Feb 2011 09:28
Good to know. Makes me wonder if the bypass valves are different from the older Gpz.
I'm using the 82 pan with the galley plugged at the front on the 91 zephyr motor. Feed oil from the rear with a captured o ring AN adapter. 180 AN fitting to feed the oil cooler. Cooler return is to the front of the pan in the normal location. Since the cooler and pump are 91 zephyr wonder if I'm getting full flow through the cooler or recycling some. I do have both valves but do not remember if I swapped them before install.
Hmmmm.....
I had a snug fit placing both AN up front chose this route to keep the feed fitting/hose away from my pipe as much as possible.
Thanks for sharing all of this prep.
Hmmmm.....
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Last edit: 12 Feb 2011 09:28 by kzr750r1.
- CoreyClough
- GPz550 Addiction
12 Feb 2011 08:37 - 12 Feb 2011 08:38
I was gurnta(going to) tap my oil temp probe here, but when I found out it sat right against the exhaust, I opted to move it to the oil level sensor.
Keep up the good work!!!
'85 GPz550(ZX550-A2)
Last edit: 12 Feb 2011 08:38 by CoreyClough.
- kzr750r1
12 Feb 2011 09:24
+1 on the level sensor mod.
Just for the record.
The Zeph pan has the casting for the level sensor but was not machined out.
Wanted to have options hence modded the 82.
Never connected the sensor and now have something that could be useful. Great suggestions.
Wonder if the case plug under the ignition would be a good spot to pick up pressure? Off to go look at the oil diagram again.
- Lorcan
- Speed Loony
13 Feb 2011 05:06
Great thread, and what a good find on the oil pump! My 750s will be getting those.
Your solid engine mounts are exactly the same as mine.
I assume your race series does not allow you to upgrade the forks? Keep up the good work.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- turboguzzi
13 Feb 2011 07:33 - 13 Feb 2011 07:56
KZR, I did pick oil pressure from that plug under the points cover in my other racer (see avatar) and it worked real fine. but why not get instead a full 83-85 oil sump that's got everyhting ready?
Still got to check clereance to the 4-1 pipe i've got, looks tight
thanks lorcan
first ebay one was really bad, looks like it chewed quite a bit of scrap steel, second one was really good, hope to get a refund...
thanks lorcan
Last edit: 13 Feb 2011 07:56 by turboguzzi.
- turboguzzi
13 Feb 2011 07:36
big package form the US arrived, time for the clutch
dont like the idea of oil getting trapped and centrifuged in the inner basket , hence drilled some holes for draining
- turboguzzi
13 Feb 2011 07:37Please Log in or Create an account to join the conversation.
- turboguzzi
- turboguzzi
- turboguzzi
13 Feb 2011 07:45
how do you delete messages????
anyway, soaked the barnett kevlar plates in oil for 10 mins. as required (left) stock friction plates (right ) had zero wear, will keep for spares..
- turboguzzi
13 Feb 2011 07:49
instead of getting stiffer clutch springs, why not preload them with .040 copper washers? pressure at the lever now is pretty stiff, hope the kevlar plates and the increased preload will be enough to cope with the improved power
