Engine break in concerns
- XL777
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
- Thank you received: 2098
...when I tested 2/3 the light stayed on the whole time. I followed the testing instructions in the dyna instructions and pull out my plugs sure enough 2/3 were not sparking. So I switched the leads and sure enough they fired. SO looks like my 2/3 module is dead...don't want to have buy a new dyna....
If not already done, would assure there's battery positive voltage on the red wire where it enters 2/3 module.
Have never gone into Dyna-S harness to see how single red power wire entering harness becomes dual red power wires exiting the harness to provide a separate red wire to each module.
Just wild guessing that maybe something's wrong inside the harness allowing red wire power only to the 1/4 module.
- XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
do you mean test where the coil and the ignition wire meet? or where the wire meets the 2/3 module on the plate?
Am interpreting where test light is reportedly staying on to mean that when the rotor magnet passes 2/3 module, the module is failing to un-ground the coil primary.
Failure to un-ground the coil primary might also be caused by a break in the signal wire somewhere between the module and the ignition coil.
Am guessing somewhat, being unaware of exactly how the light test was set up.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
Hopefully that is not the case, but I would start hunting for another ignition.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- XL777
Does anyone use a different ignition setup that is more stable? I find these old bikes always have electrical qwirks
I plan on going over every connection cleaning it and taping it together so no wire can come loose. I have done the wired george upgrade as well. Are there any other electrical qwirks I should fix that I don't know. its a lot of $$$ going through ignitions >(
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
...It could be a wire but how do you test that? there was no obvious signs of wire pinching or tear....
When needing to access the internal core of an insulated wire, for testing purposes, I use a sewing needle to temporarily penetrate the wire into the core, then connect test probe to the needle.
- PLUMMEN
- Thank you received: 104
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- TeK9iNe
- What did you do!?!
- Thank you received: 28
SOLDER all of your connection together! It saves the agony of stupid connectors, and is just as easy to snip and resolder later.
Also reduces resistance significantly over the entire system!
Use good shrink wrap if you can. if not, then a quality elec. wrap/tape is ok.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
First things first. You should verify you have a power drain on the battery or not. With the key off take the ground cable off of the battery. Then get out your multimeter and turn it to amps. Connect the positive lead to the ground cable and negative lead to the batteries negative side. It should read 0 amps. Now switch to milliamps keeping the leads in the same place. It should read no more then 10 mA and it will probably read 0. If it reads higher then that, you have a power drain and its time to go hunting.
YES... this is good advise! We do this on cars all the time with high amp testers to check alternators.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
