Engine break in concerns
- XL777
it runs and idles smooth nice through the power band. However I think my timing is still out since it seems to lack power below 6k and then takes of quickly. It still gets RPM quickly and fast too but it feels soft. I expected it to have more torque to be honest it doesn't seem much different then when I had bad rings. Could it be carb settings now that I have bigger pistons?
Bad things I notices is I still have an oil leak and I can't find the source. I'm thinking it could be my APE tensioner or the back side of the cyl base which would SUCK!!. Either way it just makes a mess
Hope to break it in some more this weekend and check the timing.
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
- Motor Head
- Thank you received: 391
- otakar
Thanks I did read the above post. I'm using casrol gtx motorcycle oil it all I have used in the past but plan on using rotella t next.
I live in a small town so to get 50 miles in town would take days haha most of the road around here post 80-110 km/hr speeds so I will have to find a back road to cycle through the gear.
reading the different posts and online opinions makes this process sound extremely sensitive or really easy hah. I guess I'll just try it and see nothing will be as bad as it was.
As long as the oil states it is SE class than you will be OK. Also purpose stated "Racing" oils are fine also. As long as it is not a SAE rated automotive oil it should be fine. If you are using bike oils, make sure they are rated SE or SF or SG or CG-3 or CG-4 or CH-3 or CH-4. It must NOT be rated SL or SM.
www.aa1car.com/library/api_motor_oil_classifications.htm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- XL777
Might want to check the three O-rings that go under the oil pressure switch adapter, for lack of a better term, that is where mine started leaking. A six mm allen and about 10 minutes was all it took to replace the o-rings.
Not sure what part of the bike you mean
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
- otakar
Sorry, do you see your oil pressure switch? I don't know which motor you have? J engine? Then it it under the carb rack, near the APE tensioner, on the block. 2 Allen Headed screws will remove the piece, 3 O-Rings live there and would be a good idea to replace.
Yes I do agree, this is a problem which eventually plagues all of these bikes especially the "J" series motors. Mine is also leaking on a freshly rebuilt motor. As stated, it is the little device with the single wire going to it, right below your cam chain tensioner.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- XL777
My carbs are stock should I be doing any rejetting now that I have 1045 cc and bigger pistons?
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- steell
Since ZDDP has only been removed from oils since the end of 2007, that would mean that these cars have over 100,000 put on them per year. And yes, many of the older cars are getting wiped out. It's all over the inter nett.
Being "all over the internet" is pretty much a sure indication it's wrong. AKA If "everyone" knows it's true, then it's probably false.
So, like I keep telling people,research!!
After tons of reading (good thing I read fast) it seems that ZDDP has been reduced from 1200/1500 ppm to 800 ppm. Can't find anything that says it has been totally removed.
Ever heard of a Tribologist?? Me neither until now. Seems to be an expert in metal to metal contact and lubrication.
Anyway the following quote is from an automotive OEM Tribologist, and it's posted on an engineering board.
drwebb (Automotive)
27 Aug 08 9:18
As I have alluded in other posts, from a formulation viewpoint I am skeptical that lower ZDDP is the root cause for two reasons:
1) Service classifications are defined mainly by oil performance and not chemistry. That means that API-licensed engine oils must have passed stringent engine Sequence tests specifically designed to gauge cam wear. This is the technical basis for recommending the latest categories as "backwards compatible" to older engines designed around previous service categories. While phosphorus content is limited in the latest categories, there has been no lessening in requirements for demonstrated cam wear protection.
2) The anti-wear effects of ZDDP tends to saturate at fairly low treat levels. This means that only a small amount is 'active' at a time, so a significant portion in 'older' formulations was there for oil performance durability over the course of the oil drain intervals. Break-in service is normally a short interval, so probably not all the ZDDP in the old 1200 ppm P oils was necessary for break-in protection.
There are a few specialty marketers who cater to the 'more is better' formulation strategy and advertise very high levels of phosphorus or zinc in their formulations. You can find one of these and try for yourself. Since such products are available, if high ZDDP were an effective fix for HP cam break-in problems word would get out that they are the solution. As that apparently has not happened then I suspect oil performance is a convenient scapegoat when there is a problem, because it's something the hard parts guys claim they can't control.
www.eng-tips.com/viewthread.cfm?qid=214619&page=1
I found tons of websites saying that the lack of ZDDP in modern oil was killing motors, but they were all selling ZDDP.
I could find no posts (only went through 10-15 pages of search results though) from anyone saying their cam had been wiped out due to lack of ZDDP (or anything else), only people saying there had been reports of such things occurring, and no links to any such results.
If it walks like a duck, quacks like a duck, and looks like a duck, then it's snake oil IMHO.
That's the results of my research anyway, I'll continue to use Shell Rotella T in my bike, and Valvoline 10w40 in my flat tappet engine car. Everyone else can use whatever they like, I won't mind a bit
This post brought to you in the interest of education, feel free to believe it or ignore it.
- otakar
drwebb (Automotive)
27 Aug 08 9:18
Since you don't believe in ZDDP, why do you use Shell Rotella-T????? :huh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
- Thank you received: 337
Phosphorus (a component of ZDDP - Zinc Dialkyl-Dithio-Phosphate) is the key component for valve train protection in an engine and 1600ppm (parts per million) used to be the standard for phosphorus in engine oil. In 1996 the EPA forced that to be dropped to 800ppm and then more recently (2004?) to 400ppm - a quarter of the original spec.
Read more: www.carbibles.com/engineoil_bible.html#ixzz0wbm0G65C
blog.motorists.org/warning-if-you-have-a...-your-oil-carefully/
Shell Rotella T which is a conventional (mineral-based) oil that was originally formulated for diesel engines. Rotella T still contains 1,200 parts per million ZDDP, according to Shell – which is as much as five times the amount found in other oils.
That is what I have also read in other places, that some oils are down to about 300 ppm or less. And, they don't want to talk about it when asked and they sure as hell don't put it on the label.
This leads us to the main point of this article--zinc, or more specifically the lack of it in today's oils. Oil companies started adding ZDDP (zinc dialkyldithiophosphate) to engine oil back in the 1950s to help reduce wear and tear during engine start-up. How important is ZDDP to your classic Mustang's engine? It reduces bearing and journal wear by a factor of 20.
www.mustangmonthly.com/techarticles/mump...ngine_oil/index.html
Like I keep saying: cam lobes are not the only surfaces subject to severe wear without film protection, they are just the ones that fail the fastest.
- T_Dub
- Thank you received: 25
As for Tribologists, I am going to be doing an internship at the Tribology department at Volkswagen AG in Germany this fall. Maybe by the end of my internship I will be able to shed some light on all this. Or even sooner, as I have a few Tribology texts out from the University library to read before I start work.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
